Author Topic: Coolant system is preasureized instantly???  (Read 2091 times)
October 03, 2008, 06:01:07 am
barlytreat
« on: October 03, 2008, 06:01:07 am »
My 1.6td is running Evans NGP+ coolant (low psi ) with a 19*22 *3 Griffin double pass NASCAR radiator and 16" Spal fan.  I'm thinking that I must be leaking compression into the coolant system.  The head is newly rebuilt though.  Any suggestion would be great.
Reply #1October 03, 2008, 06:19:16 am
saurkraut
  • 904
« Reply #1 on: October 03, 2008, 06:19:16 am »
Yup, head gasket, cracked head, or cracked block.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
'86 Audi 5000 Turbo Quatro Wagon
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #2October 03, 2008, 07:15:15 am
« Reply #2 on: October 03, 2008, 07:15:15 am »
Agree with above. My Evans wasn't pressurized when I lost my WP pulley and the temp was WAY past 250. It only expanded a little and dribbled out the overflow hose(open system)
Reply #3October 03, 2008, 07:41:22 am
« Reply #3 on: October 03, 2008, 07:41:22 am »
X3  ^^^^^^^
Reply #4October 03, 2008, 09:41:45 am
Op-Ivy
  • 513
« Reply #4 on: October 03, 2008, 09:41:45 am »
X4
The coolant system should only pressurize once it gets hot enough for the coolant to expand a bit. Then at higher temperature it should pressure to keep from boiling over.
PS: Tie her up and put her in the basement. (I didn't understand the question anyway)
Reply #5October 03, 2008, 12:27:21 pm
barlytreat
I hope it's not the block
« Reply #5 on: October 03, 2008, 12:27:21 pm »
Well it looks as though I gonna have to pull the head again.  What is the likelyhood that a 1.9 head will mate up without issue?  Btw it looks like I may be in the market for a head, if anyone has a GOOD leed please let me know.  Thanks for all of the prompt input.
Reply #6October 04, 2008, 12:01:59 pm
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
« Reply #6 on: October 04, 2008, 12:01:59 pm »
I'm putting a 1.9 aaz head on mine. PM me if you want to know what im doing. Don't take my word as anything concrete as I R n00b
Ed
