General Information
Troubleshooting
Coolant system is preasureized instantly???
Topic: Coolant system is preasureized instantly??? (Read 2084 times)
October 03, 2008, 06:01:07 am
barlytreat
October 03, 2008, 06:01:07 am »
My 1.6td is running Evans NGP+ coolant (low psi ) with a 19*22 *3 Griffin double pass NASCAR radiator and 16" Spal fan. I'm thinking that I must be leaking compression into the coolant system. The head is newly rebuilt though. Any suggestion would be great.
October 03, 2008, 06:19:16 am
saurkraut
October 03, 2008, 06:19:16 am »
Yup, head gasket, cracked head, or cracked block.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
October 03, 2008, 07:15:15 am
October 03, 2008, 07:15:15 am »
Agree with above. My Evans wasn't pressurized when I lost my WP pulley and the temp was WAY past 250. It only expanded a little and dribbled out the overflow hose(open system)
October 03, 2008, 07:41:22 am
October 03, 2008, 07:41:22 am »
X3 ^^^^^^^
October 03, 2008, 09:41:45 am
Op-Ivy
October 03, 2008, 09:41:45 am »
X4
The coolant system should only pressurize once it gets hot enough for the coolant to expand a bit. Then at higher temperature it should pressure to keep from boiling over.
PS: Tie her up and put her in the basement. (I didn't understand the question anyway)
October 03, 2008, 12:27:21 pm
barlytreat
I hope it's not the block
October 03, 2008, 12:27:21 pm »
Well it looks as though I gonna have to pull the head again. What is the likelyhood that a 1.9 head will mate up without issue? Btw it looks like I may be in the market for a head, if anyone has a GOOD leed please let me know. Thanks for all of the prompt input.
October 04, 2008, 12:01:59 pm
October 04, 2008, 12:01:59 pm »
I'm putting a 1.9 aaz head on mine. PM me if you want to know what im doing. Don't take my word as anything concrete as I R n00b
Blue 2009 CR140 Jetta CBEA/CJAA. Malone stage 2. EGR/DPF/Exhaust-valve deletes. 2.5" open exhaust. ADP Turbo swap. 1-stage nitrous kit.
THROWN ROD
General Information
Troubleshooting
