Author Topic: will these rods work on the 1.6 motor  (Read 2661 times)
September 30, 2008, 09:29:19 pm
kane66
  • 131
« on: September 30, 2008, 09:29:19 pm »
http://www.rosten-performance.com/pages/h_beam_rods.html
(the ones on the top)
1985 Jetta WBE
Reply #1September 30, 2008, 10:54:41 pm
MJF
  • 581
« Reply #1 on: September 30, 2008, 10:54:41 pm »
Nope. 1,6 rod is 136mm long and pin is 24mm.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #2October 01, 2008, 06:05:40 am
blkboostedtruck
  • 1535
Re: will these rods work on the 1.6 motor
« Reply #2 on: October 01, 2008, 06:05:40 am »
Quote from: "kane66"
can you post the main page looks interesting!
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #3October 01, 2008, 11:57:15 am
kane66
  • 131
« Reply #3 on: October 01, 2008, 11:57:15 am »
sure
I posted the one page because the vendor uses frames, and it was kinda hard to show what I was talking about.
1985 Jetta WBE
Reply #4October 01, 2008, 12:12:56 pm
blkboostedtruck
  • 1535
« Reply #4 on: October 01, 2008, 12:12:56 pm »
thanks thats understanable! looks they got conversions to turn a hydro into a mechanical head!
Duane
'66 variant 1500S
Reply #5October 02, 2008, 08:57:51 am
kane66
  • 131
« Reply #5 on: October 02, 2008, 08:57:51 am »
this guy has a lot of interesting parts... maybe if enough people wanted them he would produce some heavy duty rods for the 1.6... just an idea, as it seems the most common concern of those building high hp 1.6's
1985 Jetta WBE
Reply #6October 02, 2008, 09:17:18 am
« Reply #6 on: October 02, 2008, 09:17:18 am »
Maybe but if we change the intake manifold so the 2 middle rods weren't getting 80+% of the air bending rods would be less of a issue.
Reply #7October 02, 2008, 09:47:39 am
saurkraut
  • 904
« Reply #7 on: October 02, 2008, 09:47:39 am »
Quote from: "blkboostedtruck"
Duane
Yah, but there is no recess in the top of the lifter to accept the OEM valve shims.
Looks like you have to remove the lifter to put their 'lash caps' on the valve stem.  Which means the cam has to come out each time you adjust the valves.   :roll:
And the 'lash caps':
"the height must be grinded for each application, please specify if it is for exhaust or intake valve"
No thanks.
Maybe I should have pattened my super wizbang seat shims. :shock:
Well, the cat is out of the bag now....
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
