Author Topic: ID pump head size by part # ?  (Read 2779 times)
September 30, 2008, 07:59:12 am
  • 1739
« on: September 30, 2008, 07:59:12 am »
I'm working my way backwards trying to find out what size the head was on the 1Y 1.9 na motors. The bosch numbers based on the information i got from vagcat are : 028 130 115 PX and QX , 068 198 015A, 068 130 081 JX and 028 130 107 KX I just want to know if they are 9mm or 10mm
Reply #1September 30, 2008, 04:35:21 pm
Turbinepowered
  • 1206
« Reply #1 on: September 30, 2008, 04:35:21 pm »
Is it a pump you have in your hands? I don't know VW part numbers, but I can give you the full layout for Bosch part numbers.
Reply #2September 30, 2008, 08:20:54 pm
  • 1739
« Reply #2 on: September 30, 2008, 08:20:54 pm »
No i don't have them in my hands. I was hoping that they be cross referenced.  basically i'm trying to determine what size head would have been on a 1Y 1.9 NA.
Reply #3September 30, 2008, 09:00:42 pm
blkboostedtruck
  • 1535
« Reply #3 on: September 30, 2008, 09:00:42 pm »
i'll take an educated guess? 9mm let me know if i'm right?
this make's my 1000 post lets have a party
Duane :twisted:
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #4October 01, 2008, 04:55:37 am
« Reply #4 on: October 01, 2008, 04:55:37 am »
I have a 028 130 107 Q 1.9 NA pump and it is a 8mm. Hope this helps.
I'm moving this to the IDI section as well
Reply #5October 01, 2008, 06:28:28 am
madmatt
  • 24
« Reply #5 on: October 01, 2008, 06:28:28 am »
should be 8mm on a 1y
t3(vanagon)single cab, upright 1y
t3van aaz
t3 tdi
Reply #6October 01, 2008, 07:03:23 am
« Reply #6 on: October 01, 2008, 07:03:23 am »
Quote from: "blkboostedtruck"
Duane :twisted:
1000 posts!?
Hooray!!
Wheres the keg?
Reply #7October 01, 2008, 07:11:42 am
  • 1739
« Reply #7 on: October 01, 2008, 07:11:42 am »
Quote from: "zukgod1"
Duane :twisted:
1000 posts!?
Hooray!!
Wheres the keg?
woo-hoo [chug,chug,chug]
Reply #8October 01, 2008, 07:15:04 am
  • 1739
« Reply #8 on: October 01, 2008, 07:15:04 am »
I'm hoping it was 9mm. I just had a 10mm put on and i'm gonna drop into my transporter this friday/saturday. I just hope it gets me to the power level i need so i can then change my R&P from a 5.5 [!] to the 4.86 i got sitting in a box. Thanks everyone, at least its encouraging.
Reply #9October 01, 2008, 02:59:04 pm
madmatt
  • 24
« Reply #9 on: October 01, 2008, 02:59:04 pm »
make sure you let the engine breath and dont bother with the small 16na exhaust.If the engine is at 50degs then i use an audi80 gas manifold an a2" exhaust.My old pick would wheel spin in second first was of no use with the5.5 r&p and it was flat out at an indicated 80mph a 5 speed 3h box out of a jx bus ment i could change into top at 70mph
t3van aaz
t3 tdi
