Author Topic: Need a lot of Q's answered please help!  (Read 4953 times)
September 29, 2008, 11:02:26 pm
  • 3468
    • McScrubbins Body Wash
« on: September 29, 2008, 11:02:26 pm »
Just yes + modifications or no not a chance please!
Will a TDI ALH intake work with a Garett t3 turbo and 1.9 aaz head in my mk2?
1.9 aaz head with 8mm valves on a 1.6td hydro block? keeping the springs and lifters?
1.6 exhaust mani with the aaz head?
Please help me! I want to order my parts as soon as possible but i don't want to $#@^ up!
Reply #1September 29, 2008, 11:41:52 pm
  • 3468
« Reply #1 on: September 29, 2008, 11:41:52 pm »
I have a complete 1.6TD with a garett t3
My order so far is
1mm over pistons/rings
1.9 aaz head
8mm valves
tdi intake + gasket
egt
cam and valve guides
Reply #2September 30, 2008, 07:48:33 am
gigaz2
  • 626
« Reply #2 on: September 30, 2008, 07:48:33 am »
I think YES to all questions, but someone more knowledgeable will chime in.
make sure the head you're getting is the 8mm one before ordering the valves, there are 7mm aaz heads
Reply #3September 30, 2008, 10:50:58 am
  • 3468
« Reply #3 on: September 30, 2008, 10:50:58 am »
Yeah I know! That's what's been holding me up and is what is still currently holding me up. He seems to have 8mm intake valves but no 8mm exhaust valves.
does anyone reccomend against reusing valve springs?
Reply #4September 30, 2008, 01:41:21 pm
« Reply #4 on: September 30, 2008, 01:41:21 pm »
a tdi intake will work, but if you want to use stock plumbing you'll want an aaz intake with a 1.6td elbow on it, then u only need to grind on the back of the intake a tad to clear the turbo.  but if you're going to run an intercooler none of that really matters.
Reply #5September 30, 2008, 02:51:00 pm
  • 3468
« Reply #5 on: September 30, 2008, 02:51:00 pm »
Yes i plan to run an intercooler sorry! i should have mentioned that.
Thanks for your input!!!
Really wishing Pete Rothenbacher would reply to my email now... Or put exhaust valves on his site...
tick tock waiting for exhaust valves.... do do do
Pete Rothenbacher says on his site that a replacement oil return for the turbo on 1.6td's wont work for the 1.9td (or tdi's obviously)
is that because of differences on the 1.9 block or the head? or a combination of both? ie. height of engine
I just want to check with someone who knows
Do i need new liners if im getting my block bored 1mm over stock?
bore and over sized pistons adds $500 that i don't have to the cost of my build. I can hone for less than 100$ and get new rings for my stock pistons. Can i do that? What are the thoughts of the people?
I really need to do this quickly so if you have any thoughts at all i'd love to hear them!
Edit: okay, minus the 1mm over pistons and over boring is SUCH a huge money saver so im not going to do that anymore. Just hone + new rings and hope for the best. Am i stupid for doing that? I really can't afford the big pistons and over bore ontop of the head
Reply #6October 01, 2008, 11:10:43 am
  • 3468
« Reply #6 on: October 01, 2008, 11:10:43 am »
I really need help building this engine. Please someone help me?
Do i need a cam cover for a 1.9 aaz head or does the 1.6 cross over?
Can i use the same sprocket off my 1.6 head?
Do i need different hard lines?
Reply #7October 01, 2008, 11:32:28 am
« Reply #7 on: October 01, 2008, 11:32:28 am »
Quote from: "Smokey Eddy"
you need the 1.9 cover & the hard lines. not sure about sprocket though...
Reply #8October 01, 2008, 11:34:46 am
  • 3468
« Reply #8 on: October 01, 2008, 11:34:46 am »
Ok! thanks!
Prothe only sells 1 cam cover and it claims to fit basically all years. Doesnt give head types or anything just model and year... uhhh?
http://www.dieselvw.com/026103469EValveCover.htm
Also, anyone know where i can find hard lines for an aaz? Im trying very hard to avoid my vw import shop as it's very expensive.
Reply #9October 01, 2008, 11:54:16 am
« Reply #9 on: October 01, 2008, 11:54:16 am »
Burn_your_money may be able to get you a set.
Drop him a PM..
Reply #10October 01, 2008, 12:05:22 pm
« Reply #10 on: October 01, 2008, 12:05:22 pm »
Also I believe the 1.6 valve cover will fit the 1.9 but someone else will have to confirm to be sure.
Again, contact burn
Reply #11October 01, 2008, 12:05:57 pm
  • 3468
« Reply #11 on: October 01, 2008, 12:05:57 pm »
Hmmm okay I guess he'll get two messages now haha.
Perhaps he'll resolve the dispute between jtanguay and zukgod1 about cam cover cross over
Reply #12October 01, 2008, 12:45:33 pm
  • 3468
« Reply #12 on: October 01, 2008, 12:45:33 pm »
Machine new holes you mean? and mofify the gasket accordingly
Sorry, what do you mean by
The AAZ is mounted by three in the center that attach to cam caps.
I don't follow the cam caps thing... you don't mean the caps that hold the cam down do you?
Reply #13October 01, 2008, 01:00:38 pm
saurkraut
  • 904
« Reply #13 on: October 01, 2008, 01:00:38 pm »
Stewardc's Caddy with a 1.9TD.
Notice the nerds on the top of the valve cover.  The nerds cover the stud&nut that hold the valve cover to the head.  The studs are screwed into the caps of cam towers.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #14October 01, 2008, 01:03:24 pm
  • 3468
« Reply #14 on: October 01, 2008, 01:03:24 pm »
Ohhhhhhh  I seeee
Uhhh. Couldnt i just fill the holes on the cam and ... not ... use the top studs? I don't have machining tools and i can't pay someone to do it.
absolutely SICK ride btw.
Just thought i'd point that out.
