Author Topic: Anyone heel-and-toe anymore ??  (Read 10604 times)
September 28, 2008, 08:45:41 pm
  • 3255
    • My collection of HOWTOs
« on: September 28, 2008, 08:45:41 pm »
Now that we know enough about these diesels to make 'em scoot I miss some of the driving finesse that should come with it.
Specifically: I've not ever really been able to heel-and-toe reliably in an MK1/2/3 because of the way the pedal cluster sits.  Piece-o-cake in a Beetle !
My guess is that a spacer on the gas or brake pedal would help... anyone ever sort it out ??
Reply #1September 29, 2008, 12:22:57 am
FoXBoXRaCiNG
  • 92
« Reply #1 on: September 29, 2008, 12:22:57 am »
Not too often you here of the old skool driving ways! Something I still do, was taught to drive, on a standard, by a racer at Race City (RIP)! She taught me the heel&toe on the ol Mazda GLC wagon (RWD), scared the shat outta me when I first ever drifted a corner  :wink:
My cat has A.D.D :(
Reply #2September 29, 2008, 12:38:33 am
Op-Ivy
  • 513
« Reply #2 on: September 29, 2008, 12:38:33 am »
I don't heel-toe necessarily, but I do match my rpm when down shifting. I just let off the brake and blip the throttle.
Reply #3September 29, 2008, 03:04:32 am
Patrick
  • 1034
« Reply #3 on: September 29, 2008, 03:04:32 am »
Never tried it in a Jetta. Used to do it all the time in a V6 5 speed Pontiac Astre I built (That's a LOT of years ago!) Have to see if it's possible in the Jetta. My right foot will twist around at a pretty good angle..... :lol:
Reply #4September 29, 2008, 03:45:11 am
blkboostedtruck
  • 1535
« Reply #4 on: September 29, 2008, 03:45:11 am »
I used to do it in my type 3 a lot! when my idle was off!
but  is difficult in MK's unless the brake pedal works at a lower position!
but i have stayed away from that practice because of the instant brake light that comes on! the older master cylinders that were used in early vw's had a pressure switch and only came on with some pressure was applied!
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #5September 29, 2008, 06:23:40 am
saurkraut
  • 904
« Reply #5 on: September 29, 2008, 06:23:40 am »
I have EEE width feet, so I brake with the left side of my right foot, and blip the throttle with the right side.
Its kind of a push and pivot.  Works good.
I do it all the time.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
'86 Audi 5000 Turbo Quatro Wagon
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #6September 29, 2008, 09:01:21 am
TedV
  • 182
« Reply #6 on: September 29, 2008, 09:01:21 am »
Story from Randy Pobst who started racing with the Mk1 Rabbit Cup cars.  He would bend the gas pedal to the left to make heal-toe easier.  In 85 they switched to the Mk2 Golf. He picked the Golf, soon to be racer up at the port at night.  Drove a block away, reached down to bend the pedal to the left. Doing so he heard a SNAP. Turns out Mk2's use a plastic pedal  :shock:   he had to walk back to the guard, ask him for another pedal and a band aid.  Plastic can be sharp.
 :lol:
Sometimes I left foot brake when I autocross
Reply #7September 29, 2008, 08:02:42 pm
« Reply #7 on: September 29, 2008, 08:02:42 pm »
I do as op-Ivy and RPM match. I've tried heel and toe but haven't ever successfully done it. My brakes come in too early so I can't hit the throttle.
Reply #8September 29, 2008, 08:14:54 pm
  • 3255
« Reply #8 on: September 29, 2008, 08:14:54 pm »
Man you haven't lived till you're roaring down a winding mountain road in a 1969 VW van on road crush, rear end drifting out, heel-and-toeing as the apex tightens...
... passengers screaming....    :lol:
Reply #9September 30, 2008, 09:10:22 pm
1slowvw
« Reply #9 on: September 30, 2008, 09:10:22 pm »
I'm a big fan of rev matching, picked it up as a habit while dirtbiking when I was real young, and just transfered over to my driving everything else.
1SlowVW
Reply #10September 30, 2008, 10:51:17 pm
« Reply #10 on: September 30, 2008, 10:51:17 pm »
My 2nd gear synchro is kinda nasty so rev matching is almost a requirement, at least when it's cold.  I've never managed to figure out a way to jam my foot in there to heel and toe it though - not much room!
Reply #11October 01, 2008, 03:24:15 pm
Baxter
« Reply #11 on: October 01, 2008, 03:24:15 pm »
Double de clutch anyone?
i always have a throttle blip between gears, I also could never heal and toe to I was a left side right side kinda driver, same scenario just done different.
Reply #12October 07, 2008, 01:10:35 pm
« Reply #12 on: October 07, 2008, 01:10:35 pm »
Ya, I've also had problems with it in most of the VW's I've owned.  The best part about my Camaro was the pedal arrangement.  I also had some nice aluminum pedals made that made it easier.  I have these nice pedals in my Scirocco: http://store.cdoc.com/detail.asp?id=13721&str=2000-0174&name=Pedal+Sets%2C+Dead+Pedals+and+Footrests#
They are the nicest I have ever stepped on, but the brakes do not engage high enough and I cannot swing my foot around to the accel pedal.  The Corrado isn't as bad, I suspect with proper pedals I should be fine with it.  In the meantime, I still RPM match downshifting most of the time, just not while braking.  :P
Reply #13October 07, 2008, 05:27:30 pm
smoken u
  • 231
« Reply #13 on: October 07, 2008, 05:27:30 pm »
I double clutch most of the time, and heel toe occasionally, but like everyone says its not easy in the MK II, although I do brake boost very often while going around corners, find it makes it spool faster. :twisted:
1990 VW jetta 1.6 td, 2.5" exhaust, no muffler, governor mod 2010 edition, K&N filter. and now 66 hp and 136 ftlbs.
project 1.6 liter in the works  :)
You don't rev a VW diesel, you increase the clatter.
Reply #14October 07, 2008, 08:54:55 pm
  • 3255
« Reply #14 on: October 07, 2008, 08:54:55 pm »
Great discussion guys... much appreciated.
Here's something to put you in the mood.
Here's a pretty good tutorial from a pretty good car mag .
