Author Topic: windage or not to windage that is...  (Read 2856 times)
September 27, 2008, 10:16:34 am
  • 1739
« on: September 27, 2008, 10:16:34 am »
Finally building up my 1.9 na that used to be an ADG industrial motor which is going into my transporter. It came with the windage tray which has the oil pan gasket molded to it, so of course it's now scrap since i removed the pan. I wouldn't think it would do much good since the motor will be tilted so far over. I was going to replace the gasket with a regular one [the nice rubber molded one].  Any suggestions , opinions, hate mail on this ?
Reply #1September 30, 2008, 12:53:03 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #1 on: September 30, 2008, 12:53:03 pm »
hate mail
 :D
Reply #2September 30, 2008, 01:15:05 pm
« Reply #2 on: September 30, 2008, 01:15:05 pm »
i'd keep it.  the gasket is rubber and re-useable.  it really helps oil from whipping up and foaming and can even give 1-2 hp at high rpm  8)
Reply #3September 30, 2008, 04:34:17 pm
  • 1739
« Reply #3 on: September 30, 2008, 04:34:17 pm »
Well in a way the question is moot because i ordered another one and since i wanted oem quality they sent me the same thing. I only ask because believe it or not, on some motors it's a no-no.
Reply #4October 01, 2008, 02:07:55 am
madmatt
  • 24
« Reply #4 on: October 01, 2008, 02:07:55 am »
I always fit them on mine and it does help to keep the oil where it sould be but on the track my bus will still lose oil pressure on long fast right hand bends always vent the oil into a catch tank to avoid it getting into the intake.on some bellhousings you have to open up the bottom hole as the rubber gasket is a little thicker and moves the sump.
t3(vanagon)single cab, upright 1y
t3van aaz
t3 tdi
Reply #5October 01, 2008, 05:28:21 am
saurkraut
  • 904
« Reply #5 on: October 01, 2008, 05:28:21 am »
Quote from: "the caveman"
Which ones?
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #6October 01, 2008, 06:25:57 am
madmatt
  • 24
« Reply #6 on: October 01, 2008, 06:25:57 am »
on the t3 the alloy sump bolts to the bellhousing but not all need to be modified some bolt straight on but on a few ive had to open up the hole right at the bottem. This is on a t3 and not a eurovan t4
t3van aaz
t3 tdi
Reply #7October 01, 2008, 07:20:15 am
  • 1739
« Reply #7 on: October 01, 2008, 07:20:15 am »
Quote from: "saurkraut"
Which ones?
Not diesel but VW air cooled hi-po.
Reply #8October 01, 2008, 07:21:50 am
  • 1739
« Reply #8 on: October 01, 2008, 07:21:50 am »
Quote from: "madmatt"
Crap. Oh well if i have to i will try to oval the bell housing. I really don't want to strip to threads of my pan.
Reply #9October 01, 2008, 02:43:55 pm
madmatt
  • 24
« Reply #9 on: October 01, 2008, 02:43:55 pm »
its just the 1 bolt hole and its normally only 1/2mm that needs to be taken out as the rubber gasket is thicker that the old style and moves to sump.but as i said some bolt straight on others need to be opened up
t3van aaz
t3 tdi
