Author Topic: how much will the stock 1.9TD clutch take  (Read 2592 times)
September 24, 2008, 08:07:38 pm
James8485
  • 223
« on: September 24, 2008, 08:07:38 pm »
fueling up, bigger  turbo(K24)  , bigger exhaust and 1.6TD boost pin should the stock clutch hold with these few advancments??
is ther an upgrade thats a direct replacment?
i think mine is slippin a bit and its only 1 1/2 old......
 this possible>
---------James--------
Reply #1September 25, 2008, 04:55:41 am
« Reply #1 on: September 25, 2008, 04:55:41 am »
cable clutch?  where does the clutch engage? AFAIK you can install a VR6 clutch upgrade...  1.9's should be able to hold quite a bit of power before letting go... what is your driving style like? the more you ride/play the clutch, the more it will wear...
Reply #2September 25, 2008, 05:28:31 am
MJF
  • 581
« Reply #2 on: September 25, 2008, 05:28:31 am »
What car? You need 02A tranny for VR6 clutch.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #3September 25, 2008, 09:57:46 am
1slowvw
« Reply #3 on: September 25, 2008, 09:57:46 am »
I run a AZZ in a mk2, boost, pin, fuel increase, 2.5 inch turbo back exhaust, FMIC, K-24, you know the usual haha, and i just put in another stock clutch, this one now has about 800km on it, and is slipping already, I will be going 6 puck soon. That being said i run an 020 small w/small spline, I belive a big spline set up, with the larger clutch surface would be able to take more punishment.
Also my driving style is um... spirited.
1SlowVW
Reply #4September 25, 2008, 12:01:28 pm
« Reply #4 on: September 25, 2008, 12:01:28 pm »
Quote from: "1slowvw"
1SlowVW
hmmm  :lol: is it in launches that you feel it slip, or is it when you really stomp on it and boost is going crazy?
i've driven a vw where the clutch would just break loose because of the power... very fun car to drive until that started to happen  :(
Reply #5September 25, 2008, 12:13:49 pm
  • 3468
    • McScrubbins Body Wash
« Reply #5 on: September 25, 2008, 12:13:49 pm »
yeah mine isn't going to take what im building. =(
is a vr6 the only way to go?
Reply #6September 25, 2008, 12:28:06 pm
subsonic
  • 1836
« Reply #6 on: September 25, 2008, 12:28:06 pm »
What are you using for a pressure plate?
Reply #7September 25, 2008, 12:37:00 pm
  • 1739
« Reply #7 on: September 25, 2008, 12:37:00 pm »
I had my 98 TDI jetta chipped and bigger nozzles and everytime i launched with anything more than 1/2 throttle you could smell the clutch cooking. My friend bought the car but without the nozzles and it's still the same clutch after a year. All to say -yes you need a VR6 clutch and pressure plate.
