S-PAutomotive.com
Author Topic: Starting a turbo build...Videos of it running :D  (Read 102143 times)
Reply #60April 05, 2009, 06:54:27 pm
CoolAirVw
  • 175
Starting a turbo build and...
« Reply #60 on: April 05, 2009, 06:54:27 pm »
Keep up the good work.  I just wanted to say when you get under the car pull the brake lines down, just move them out of the way, no need to open the system, wire wheel and "treat" the little studs that the brake line clips fasten too, with rust treatment.  Those studs/clips hold water and make rust.
There used to be a stud in this picture but instead there is a rust hole.  The dark spot in the middle is carpet.
Several of my brake line clip studs had similar holes.
After replacing 1/4 floor, I treated mine with por 15 products and then undercoated.  I soaked the studs with undercoating spray, then pressed the brake line clips back on.
See my thread here...
http://www.vwdieselparts.com/forum/viewtopic.php?t=6255
85 Jetta Turbo Diesel
75 Porsche 914
93 GMC Truck
99 Caravan <--wifes gotta drive something :)
Reply #61April 05, 2009, 10:07:20 pm
  • 7834
« Reply #61 on: April 05, 2009, 10:07:20 pm »
Thanks for the advice. I have this spray galvanizing stuff I sell at work that I am using right now and will epoxy primer and undercoat it all when I am finished. I am also welding in *galvanized* sheet metal. I have milk and a respirator and a blow gun and I hold my breath while welding...I don't even feel sick :lol: .  I know its poisonous but I am taking every precaution and it is working so far.
 I welded most of the day today. I got the back of the drivers side lip done...not the entire back 1/4 just the lip that stiffens it all up. I also got some of the pass side holes fixed.
 My problem now is how much do I want to weld? Or what should I weld? I obviously need to fix the holes, but where to stop.
Reply #62April 19, 2009, 10:51:58 pm
  • 7834
« Reply #62 on: April 19, 2009, 10:51:58 pm »
I found out today that if you grind the surface about 1/4" to 1/2" off the edge of the galvanized plate that the fumes are next to nothing :D . I have 1 or 2 more welds on the passenger side and then I will move to the drivers side. I have taken every little clip out and welded it shut and sprayed my cold galvanizing compound on it. So far I have learned to mig weld pretty good, I could always arc, but the mig hated me. Best advice a guy gave me was PUSH the mig. I was used to PULLING the arc and that was 1/2 the battle. I will post pics hopefully tomorrow.
Reply #63April 20, 2009, 02:54:32 am
TurboJ
  • 661
« Reply #63 on: April 20, 2009, 02:54:32 am »
Good work, mate!
All these little beauties need is a little love, and you're clearly showing yours just that! Bet she's going to turn into a monster with that new heart though  :twisted:
Jetta II 1.6 TD 'Project 200'
Reply #64May 02, 2009, 06:23:56 pm
  • 7834
« Reply #64 on: May 02, 2009, 06:23:56 pm »
I have finally decided what to do with the floor and made some progress. I am now out of shielding gas again...I am positive that TSC screwed me on this batch :evil:  Well here is some pics I got a lot more to go but at least now I can get my head around it.
This one I wanted to see how seamless I could make it and it turned out perfect. All of the gray is cold galvanize not primer.
I did this to strengthen the seat bracket and have something to weld to
I am going to weld this piece of conduit to make it more rigid
Hillbilly Tools and shop= my brake
couple of shots of the old floor
Finally my biggest challenge and hold up TACKED in place
It would have been easier for my cheap --- to buy a rust free car and have it shipped, but at least now I will have some Galvanized pannels and shouldn't do this again. I still have the fender, front part of the floor, and a little piece on the passenger side to deal with but it won't be long. Oh and I am going to replace part of the battery tray since it is missing too.
Reply #65May 22, 2009, 06:20:27 pm
  • 7834
Re: Starting a turbo build and...
« Reply #65 on: May 22, 2009, 06:20:27 pm »
Look what has happend here since the site was down. Thanks to Zuk and 53 willys for clutch recommendation. It is a clutchnet 210mm red pp with a 210mm 6 spring 6 puck red disc with the small 24 spline hub. I think it is the setup for the 8v scirocco? Anyway I have a scheme for my engine color what do you think?
Have you figured out what the scheme is yet? A little more welding and then put the engine together...maybe in June I will have it going:D It won't be too pretty, but I want to make sure the thing runs before I paint it next summer. If I get that ambitious.
« Last Edit: July 02, 2009, 08:16:04 am by theman53 »
Reply #66May 23, 2009, 02:12:34 pm
« Reply #66 on: May 23, 2009, 02:12:34 pm »
i really dig the chevy orange engine. its gonna have at LEAST 50 more horses just cause of that sexy paint job.
Reply #67May 24, 2009, 07:09:56 am
« Reply #67 on: May 24, 2009, 07:09:56 am »
Easy.. and much more Sex Appeal. Loooooking gooooood Lucas!
« Last Edit: May 24, 2009, 07:22:54 am by 8v-of-fury »
Reply #68May 25, 2009, 06:00:41 pm
TurboJ
  • 661
« Reply #68 on: May 25, 2009, 06:00:41 pm »
Wow.
Really good looking engine parts!
I hope mine will look even half that good...
Good luck with your project!
P.S.  Your inlet mani will soon be on its way to your door...  ;)
Reply #69June 13, 2009, 12:04:08 am
macka
  • 957
« Reply #69 on: June 13, 2009, 12:04:08 am »
my brother made a small vent for welding by using a duct vent pusher fan, a length of dryer hose, and a floor vent. He put the floor vent section right to the suction side of the duct fan section, and the dryer hose goes away from you. I've used it twice for floor work inside a trunk and inside the cockpit. It sucks out most of the fumes, and gets them out of the area you are working.
Quote from: Vincent Walden
I do know that I drive torque,  while listening to my friends prattle on about horsepower.
Reply #70July 17, 2009, 09:48:51 pm
  • 7834
« Reply #70 on: July 17, 2009, 09:48:51 pm »
Well I put a hole in the oil pan tonight...on purpose I needed a turbo drain. I also have been busy on the intake side. Also, someone wanted a picture of what the log style manifold looked like inside so here it is. I ported a bunch to get this to match the gasket. I had it welded before I started because I knew it would be thin on the back side.
I also wanted it to stay with the color scheme so black it is.
« Last Edit: July 18, 2009, 08:43:29 am by theman53 »
Reply #71July 18, 2009, 01:01:22 am
lovinthedeez
  • 489
« Reply #71 on: July 18, 2009, 01:01:22 am »
please tell me more about your beautiful cis intake pleasey. :D
Reply #72July 18, 2009, 08:52:48 am
  • 7834
« Reply #72 on: July 18, 2009, 08:52:48 am »
This was a long time comming. Turbo J and the AKI-76 were a team on this. Aki built it and Turbo J did the paperwork stuff.
    I wanted something built and after talking to people I realized that unless they gave me the super secret mathwork for the slot in the plennum I couldn't do it. Aki said he would do it for a really reasonalbe price, then all I had to do was wait 6 months and grind away like you see here. It is actually not a CIS intake I believe he said it was for a D24 6 cylinder that he hacked a cylinder off of. It could have been something else or a 5 cylinder, but I am almost sure it was a volvo part. The ports didn't match the gasket at all well so I had to take off about a 1/4" all the way around and after porting the stock VW intake and this one I can say for sure that this one has a way harder grade aluminum. Polished it with some of my 3M 777F cartridge rolls which are more for metal/stainless and it didn't load like usual. That is about all I can tell you.
Reply #73July 18, 2009, 10:33:30 am
lovinthedeez
  • 489
« Reply #73 on: July 18, 2009, 10:33:30 am »
so how much would it cost if i found said manifold, and did said porting, and sent it out.  don't care how long it takes, take another month if six isn't enough.  you could im me if you'd like.  that thing is a beaut.   :P
Reply #74July 19, 2009, 05:14:39 pm
  • 7834
« Reply #74 on: July 19, 2009, 05:14:39 pm »
Any ideas???
I have no idea what I am going to do now, I sold the stock intake to pay for this partially.
