Author Topic: 1.6 TD - SB and RA heads - Are They The Same?  (Read 3875 times)
September 24, 2008, 03:22:49 pm
Gernster
  • 87
« on: September 24, 2008, 03:22:49 pm »
My RA engine has spat its headgasket and when I've pulled it off its full of cracks!!
Been offered an SB head, is this a direct fit?
Reply #1September 24, 2008, 07:16:22 pm
gigaz2
  • 626
« Reply #1 on: September 24, 2008, 07:16:22 pm »
JR, SB and RA are interchangeable as far as I know.
as long as they are all hydraulic (some JR are mechanical) they can be swapped.
Reply #2September 24, 2008, 11:48:38 pm
cpv
  • 10
« Reply #2 on: September 24, 2008, 11:48:38 pm »
it willbolt right on, on ETKA the difference in the code is given only by the last letter, no major difference...
Reply #3September 25, 2008, 01:12:46 am
Gernster
  • 87
« Reply #3 on: September 25, 2008, 01:12:46 am »
good good  :lol:
what about putting a K24 Turbo on to replace the Garett T2, will is fit straight on or will i need the manifolds, water & oil feed pipes etc?
Reply #4September 25, 2008, 03:40:47 am
cpv
  • 10
« Reply #4 on: September 25, 2008, 03:40:47 am »
i did just abut the same swap...it should be a staright fit, appart the oil return hose and the air inlet(filter-turbine) that could differ in diameter.
Reply #5September 25, 2008, 04:28:02 am
Gernster
  • 87
« Reply #5 on: September 25, 2008, 04:28:02 am »
did you notice any diference in the way the car drove?
Reply #6September 25, 2008, 05:16:33 am
cpv
  • 10
« Reply #6 on: September 25, 2008, 05:16:33 am »
i don't have the sb/ra...i have the jr, i had a big stock turbo t3...that kicked off after 3000rpm, now i went with the kkk from an 1.9 aaz(it kicks off at 2500rpm, in comparisson with the sb kkk/garett this aaz is slightly bigger....i would stay with the stock one on your RA/SB...i had the sb on a audi 80 and it began filling up to 0.82 bar at only 2000 rpm...that is a very quick response...
ps....you can rarely find a water cooled turbo...as yours is...
