Author Topic: Clear pic of the governor mod  (Read 6560 times)
Reply #15September 19, 2008, 12:41:43 pm
  • 3468
    • McScrubbins Body Wash
« Reply #15 on: September 19, 2008, 12:41:43 pm »
sorry i didn't remove the intermediate spring. I was confusing my self as usual.
I did what zukgod1 did
Reply #16January 13, 2009, 02:18:47 am
  • 2932
« Reply #16 on: January 13, 2009, 02:18:47 am »
In my opinion Vincent did it right,.. sort of.
 He did the right spring,... but what I did was remove the spring and put a 1/16" thick (I think it was 3/16 hole) washer in place of the spring.
 As soon as you remove the spring you'll know what I mean. The spring holders only have a 1/16" gap between them. Fill it and it won't compress.
 Results: power all through the range and no surging (I don't mean turbo surge),.. and a smooth idle.
 It will be hard to hold it at 2000 RPM when out of gear,... it will want to climb. But with it in gear there is no problems.
Reply #17January 13, 2009, 03:28:09 am
regcheeseman
  • 714
« Reply #17 on: January 13, 2009, 03:28:09 am »
I removed the intermediate and replaced with a stack of M3 washers the same length as the spring.
I suffered a slight flat spot about 1600 - 1700 rpm that may or may not be linked to the gov mod
I never touched the main spring as I believed it would only effect the revlimit and not have any effect on the fuelling in the real world use rev range (I like to shortshift around 3000)
Am I wrong in this assumption?
