Author Topic: Clear pic of the governor mod  (Read 6567 times)
September 18, 2008, 10:54:03 am
rabbitpower
  • 45
« on: September 18, 2008, 10:54:03 am »
Can some post a pic or link with a clear photo of the Main spring shimmed on the governor?. I have searched but can't seem to get a clear indication of the critical location. I want to make 100% sure I do this right when i reseal the pump.
Thanks!!!
Reply #1September 18, 2008, 11:10:25 am
53 willys
« Reply #1 on: September 18, 2008, 11:10:25 am »
I will be moding mine today...I will snap a pic of mine and post it later if you don't have a pic today from anybody else..
Reply #2September 18, 2008, 05:57:43 pm
rabbitpower
  • 45
« Reply #2 on: September 18, 2008, 05:57:43 pm »
That would be great. I am just a little confused by some people shimming the intermediate, and others the main. It seems the safer way to go is the main spring.
I see where the intermediate ( Short spring) seats travel. I don't have any shims in between this area, there is just an approx .200 gap
I am guessing that to shim the main spring (longer spring) it must have a spacer inserted to keep the Large spring from travelling?. The problem is that it looks like this would have to be a very large shim!!
Sorry for all the basic questions, I know this topic has probably been beat to death but I am resealing the pump this weekend and If I can't find the info I am just going to reassemble the pump with a stock governor.
Reply #3September 18, 2008, 09:34:53 pm
  • 3468
    • McScrubbins Body Wash
« Reply #3 on: September 18, 2008, 09:34:53 pm »
I uhh
If i remember ... removed the intermediate spring entirely and replaced it with like 5 washers or something. something like a solid sleeve.
Acceleration went way up. So did the smoke... expectedly
Reply #4September 18, 2008, 11:35:35 pm
« Reply #4 on: September 18, 2008, 11:35:35 pm »
A couple of pictures snagged from the internet that may help:
Reply #5September 18, 2008, 11:56:01 pm
allsierra123
« Reply #5 on: September 18, 2008, 11:56:01 pm »
What does this mod accomplish? How safe is it on to run?
Reply #6September 19, 2008, 03:20:39 am
dillenger1
  • 777
« Reply #6 on: September 19, 2008, 03:20:39 am »
Dont touch the intermediate spring.It causes drivability issues
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #7September 19, 2008, 05:59:04 am
saurkraut
  • 904
« Reply #7 on: September 19, 2008, 05:59:04 am »
I haven't tried the governor mod, but I have gotten excellent results by backing out this screw a few turns:
The ball pin on the throttle arm has to be moved inward, and a readjustment of the cable jesus clip is needed.
Its also easily reversable, and I have witnessed no bizzar drivability issues.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #8September 19, 2008, 06:55:03 am
« Reply #8 on: September 19, 2008, 06:55:03 am »
I have my main spring completely removed and replaced it with a steel rod then I shimmed the intermediate spring with a couple washers.
After I was done I realized there is only about 2mm of movement in the intermediate spring anyway and the 2 washers I put in there pretty much took that space up.
My car drives fine, the cruise works great as well.
Shim away!!!!!
Reply #9September 19, 2008, 06:58:03 am
rabbitpower
  • 45
« Reply #9 on: September 19, 2008, 06:58:03 am »
Quote from: "dillenger1"
I have heard this from other people as well. I have 2 shims made up.
I can't see the pics on this P.C so I can't confirm the location
#1 is approx .056 thick and will take up the slack in the itermediate spring, disabling it.
#2 is approx .533 thick and would totally disable the main spring.
The question is now, which one should I use?
EDIT*** I just read the post above and it answered my question. Thanks!!!!
Reply #10September 19, 2008, 06:59:17 am
« Reply #10 on: September 19, 2008, 06:59:17 am »
Get a thinner one for the intermediate spring and use the larger one for the main spring.
Reply #11September 19, 2008, 07:01:34 am
rabbitpower
  • 45
« Reply #11 on: September 19, 2008, 07:01:34 am »
Quote from: "zukgod1"
So the point is to not take up ALL the slack, just partial in the intermediate spring?
I will take some pics of these parts and if the car starts and runs fine I will send them to a Mod on the forum to post.
Reply #12September 19, 2008, 07:04:53 am
« Reply #12 on: September 19, 2008, 07:04:53 am »
Yes you want to just take up some of the slack in the intermediate spring. You can completely disable the main spring.
Reply #13September 19, 2008, 10:02:02 am
allsierra123
« Reply #13 on: September 19, 2008, 10:02:02 am »
what happens when you do this mod?
Reply #14September 19, 2008, 11:16:15 am
« Reply #14 on: September 19, 2008, 11:16:15 am »
The engine will rev till you let your foot off instead of it just hanging at 4000 +/-
