Author Topic: TDI intake + AAZ head  (Read 2200 times)
September 15, 2008, 08:42:25 pm
  • 3468
    • McScrubbins Body Wash
« on: September 15, 2008, 08:42:25 pm »
Will a TDI intake fit with an AAZ head + garett t3 and 1.6TD exhaust manifold
I know the TDI intake has to be ported to line up nicely but other than that will it fit alright with the turbo and exhaust manifold?
Reply #1September 15, 2008, 08:45:19 pm
« Reply #1 on: September 15, 2008, 08:45:19 pm »
i'm pretty sure the TDI intake is bolt on, as it has the same D shaped ports as the 1.9 IDI.  different story if you're using it on a 1.6 though.  not sure if it would accomodate the T3/K24 turbo though.
Reply #2September 15, 2008, 09:34:08 pm
  • 3468
« Reply #2 on: September 15, 2008, 09:34:08 pm »
crap. I know it bolts on but im mostly concerned about a 1.6 exhaust mani being on there too and the T3 is a really big concern. I'm sure other people have done this though
Please someone chime in!
Reply #3September 16, 2008, 03:14:20 am
dillenger1
  • 777
« Reply #3 on: September 16, 2008, 03:14:20 am »
I successfully used a alh intake with t3 manifold!there is some grinding of the support holes on the back(they stick out),but those arent needed anyway.this was on a 1.6 though.I dont know of differences in the casting of the head.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #4September 18, 2008, 09:33:08 pm
  • 3468
« Reply #4 on: September 18, 2008, 09:33:08 pm »
hopefully the same dillenger1!!!
I ground those support things off about 2 years ago when i did my first hg
