Deleting AC
Topic: Deleting AC (Read 2252 times)
September 13, 2008, 04:20:11 pm
Dieselumbrado
Newbie
Deleting AC
September 13, 2008, 04:20:11 pm »
I would like to know if is possible to remove de AC bracket without disturbing the IP.
The car is a 82 Rabbit.
September 13, 2008, 05:08:32 pm
blkboostedtruck
Deleting AC
September 13, 2008, 05:08:32 pm »
this is the for sale section it will be moved to the right section by the moderators!
but to answer your question i'm pretty sure you can remove it without messing with the I.P. !
if i recall correctly?
Duane
injector rebuilds call 414-840-1395 for faster service not on line much!
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
3 jettas '82' '04 '14TDI
September 13, 2008, 05:17:08 pm
RabbitGTDguy
Deleting AC
September 13, 2008, 05:17:08 pm »
Yes, the IP bracket on an MK1 is integral to the motor mount setup. A/C can be removed without having to mess with the IP pump. It is a seperate bracket...
This is actually across platform as far as transverse mount engines go.
Joe
1972 VW Westfalia
2001 Audi TT 225 Quattro Roadster (something newer
September 13, 2008, 07:22:54 pm
Deleting AC
September 13, 2008, 07:22:54 pm »
And just like that it is moved.
You might not be able to get it off without taking the pump off. Some of the brackets have a stupid design and depending on where the pump is rotated to you won't be able to get a socket in there. Sometimes you can sqeeze a wobble extension in. It depends on what style of bracket you have, there are several.
Deleting AC
