Fighting a speeding ticket.
Topic: Fighting a speeding ticket. (Read 4106 times)
September 08, 2008, 06:05:11 pm
foxracer1
Authorized Vendor
September 08, 2008, 06:05:11 pm »
I swapped the trans in my car from an AGS 3.89 r&p to a CHE 3.67 r&p. I knew the speedo was off due to the swap and i have taller tires on it. I got pulled over in Indiana going 68 in a 55. My speedo is off at least 10mph. I installed the red speedo gear and its helped but its still 5 mph off. I used the girl friends GPS to check speed. I know those aren't 100% accurate but it has to be close.
To make this short i need to prove to the judge that my cars speedo was inaccurate and that i have "fixed it" with the gear to eliminate getting the citation on my record. I go wednesdya evening. Any ideas?
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
September 08, 2008, 06:15:20 pm
blkboostedtruck
September 08, 2008, 06:15:20 pm »
call AAA and see if they have a speed check trailer near ? i've seen them do actual test in thier parking lots for speedometers!
or ask the distric attorney for a different plea and tell them you balieve your equipment is defective!
good luck been there done that!
Duane
injector rebuilds call 414-840-1395 for faster service not on line much!
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
3 jettas '82' '04 '14TDI
September 08, 2008, 06:31:41 pm
foxracer1
Authorized Vendor
September 08, 2008, 06:31:41 pm »
My boss thinks i can talk to the district attorney and see if i can plea defective equipment. I guess i'll see. Thanks for the help.
91 S10 305 TPI T56
September 09, 2008, 08:35:10 am
spencebm
September 09, 2008, 08:35:10 am »
good luck Tom, I wish I had that excuse
dont give them any money
Ben Spencer
September 09, 2008, 09:04:32 am
September 09, 2008, 09:04:32 am »
well good luck on the defective equipment... they might want a full inspection done on the car though... this will only work once :lol:
i hope this works out for you!
September 09, 2008, 11:38:35 am
duffer
September 09, 2008, 11:38:35 am »
If you got a speeding ticket
in a 1986 VW Diesel, I think
you should frame it, hang
it on your garage wall and point
proudly to it when your friends
drop by to scoff at your car
September 09, 2008, 12:04:51 pm
Mark(The Miser)UK
September 09, 2008, 12:04:51 pm »
Speeding over here and then claiming defective equipment, might escalate the problem. Like unauthorised 'mods' invalidating your insurance :shock:
Good luck...
Mark-The-Miser-UK
September 09, 2008, 02:11:26 pm
foxracer1
Authorized Vendor
September 09, 2008, 02:11:26 pm »
I don't think they will get that picky. I will state that the tires are larger than factory causing the speedo to read slower. Also the ring and pinion in the trans is taller than the trans that originally came in my car from the factory. All while acting like this is how i purchased the vehicle. Either way i have to pay them court cost.
91 S10 305 TPI T56
September 09, 2008, 04:17:21 pm
Turbinepowered
September 09, 2008, 04:17:21 pm »
Being as honest as possible reduces the possibility of perjuring yourself. You changed out the transmission, this changed the speedometer. You believed you had that fixed (gear swap), but didn't take into account the tires and will get this remedied.
September 09, 2008, 08:13:09 pm
foxracer1
Authorized Vendor
September 09, 2008, 08:13:09 pm »
You have a point there. I'll probably be mostly honest. I mean it was reading slow. I didn't notice it till i looked at the speedo cause i saw the cop behind me.
91 S10 305 TPI T56
September 09, 2008, 08:28:26 pm
September 09, 2008, 08:28:26 pm »
just remember anything you said to the officer will most likely be brought up in court. they take very good notes. or should.. :roll: :lol:
so hopefully you didn't tell him much about your tranny :lol:
Reply #11
September 11, 2008, 02:22:28 pm
arb
Reply #11 on:
September 11, 2008, 02:22:28 pm »
I had the same thing happen in Michigan a number of years back.
I took it to a garage and had a certified mechanic I did not know write up a repair estimate and stated the speedo was off at least 16 mpg.
The Judge did not care. - I was guilty.
Years later, when my record was clean again I got several speeding tickets. I talked to the officer before the hearing and told him I had a clean record and would like to plead guilty to "Impeeding traffic" - same court costs, but no points.
That worked both times, but the cop or DA has to agree. The DA never agreed but the cop did so they were both cleared of points.
Also, in Michigan, unless it is a JUDGE, not a magistrate or reff, you can NOT pleed guilty with explanation and hope he will dismiss the points. Only a Judge can. So, unless the cop / DA agrees first, pleed NOT guilty and show that you had defective equipment.
good luck.
