Author Topic: ~My 91 GLI to 1.6TD conversion build up~  (Read 157109 times)
Reply #405July 30, 2009, 09:19:34 pm
53 willys
Re: ~My 91 GLI to 1.6TD conversion build up~
« Reply #405 on: July 30, 2009, 09:19:34 pm »
Any action? What are the specs on the charger? turbine A/R wheel trim comp A/R trim? comp map? We all wanna know. And i wanna know how she runs.
I'm at work right now....I will try and post the turbo specs in the morning when I can get to my personal email.
I sold my house and moved this last 2 months...so sadly the vw has been on the back burner while I'm getting the new house set-up and the the shop settled in....it's really been crazy and I have been bumming out on my self for not getting it done yet... :-\
Should have some more updated exhaust manifold pics soon......
Reply #406July 30, 2009, 09:35:03 pm
53 willys
« Reply #406 on: July 30, 2009, 09:35:03 pm »
awesome job on the exhaust! did you make the plate yourself or can you buy it pre-made???  are you going to have it ceramic coated?
thanks bud....that header plate came from techtonics tuning (sp?) I was gonna make one but I did not have any 1/2" plate instock and I did not want to buy a big sheet at the time...so I went the easy way out..lol
I might coat it???? have not really thought about it really.....I have had great luck with the cheap 1600* spray paint so.... :-X ;D
naw just joking...I wont high temp paint this header....probably just get some "HPC coating put on it since their shop is only like 10 mins from my house.
« Last Edit: July 30, 2009, 09:42:02 pm by 53 willys »
Reply #407July 30, 2009, 09:40:50 pm
53 willys
« Reply #407 on: July 30, 2009, 09:40:50 pm »
Just read this entire thread in 2 sittings.  :o WOW I am completely humbled by your build. This car is totally sick. You sir have inspired me to push my aaz swap a little further than I had planned. I can't wait to see where this goes.
hey thanks bud...it's been a lot of work, time and money for an old car.....I have had a great time building though!! ;D
Reply #408August 22, 2009, 12:12:48 pm
53 willys
« Reply #408 on: August 22, 2009, 12:12:48 pm »
got a small update here...
http://vwdieselforum.com/forum/showthread.php?t=6&page=6
I will post the 2 turbo maps I have as well...
Reply #409August 26, 2009, 03:39:06 pm
53 willys
Reply #410August 26, 2009, 07:12:03 pm
FoXBoXRaCiNG
  • 92
« Reply #410 on: August 26, 2009, 07:12:03 pm »
Deadly  :o
My cat has A.D.D :(
Reply #411August 27, 2009, 07:07:23 am
53 willys
« Reply #411 on: August 27, 2009, 07:07:23 am »
Deadly  :o
thanks bud..it's good to finally get back to work on the project....
Reply #412August 27, 2009, 07:08:44 am
53 willys
« Reply #412 on: August 27, 2009, 07:08:44 am »
got my block mounted oil drain done..
more that here..
http://vwdieselforum.com/forum/showthread.php?p=116#post116
Reply #413August 27, 2009, 08:54:22 am
« Reply #413 on: August 27, 2009, 08:54:22 am »
About time...
Reply #414August 30, 2009, 12:06:46 am
53 willys
« Reply #414 on: August 30, 2009, 12:06:46 am »
About time...
haha.... I know right!?
I have had this car for over a year and only put about 1000 miles on it.. :P
It's getting closer..... :D
more updates here aswell
http://vwdieselforum.com/forum/showthread.php?t=6&page=7
Reply #415August 30, 2009, 08:46:19 am
« Reply #415 on: August 30, 2009, 08:46:19 am »
i think i wanna build a header like yours.
Reply #416August 30, 2009, 10:37:29 pm
53 willys
« Reply #416 on: August 30, 2009, 10:37:29 pm »
DO IT!! just dont ask me to do it for you  ;D...it was a PILE OF WORK!!...I'm just glad it's done..I was working on the down pipe this afternoon and I was thinking the down pipe felt really easy to build after all the crazy notches and fitting of tubes for the header..hahaha
That looks really good.  Can you get more of the exhaust flanges?  How much?
Thanks Andrew...are you referring to the main header flange?? if you are I just bought this one from techtronics tuning...
http://www.techtonicstuning.com/showpart.asp?partnum=251.290
I think I paid about $50 for it??
they make it with SS...but the SS version is 4 separate pieces..not all one piece like the 1/2" steel version....
I was kinda scared to try and weld the 4 piece one...I would probably warp it with my welds..
but the real reason I went mild steel with my SS tubing was I did not decide to go with the SS until after I had already received my flange...
Reply #417August 31, 2009, 09:37:30 am
« Reply #417 on: August 31, 2009, 09:37:30 am »
why would i ask you to build it? i can cut and weld just as good as the next guy. i built a turbo header for my 19.5 horse briggs lawn mower engine. it has a T3 off a lebaron on it. it doesnt really spool down low at all, but its sure cool having a lawn mower with a turbo, a header, and half of a VW injection system. you should see the look on peoples faces when i fire that thing up and give her some throttle. its just a bit louder than stock with the turbo, and i have a 2.5" tail pipe comin off the turbo. still needs a bit of tuning tho, back fires quite a bit when you let off the throttle.
but yea, i can build it, i even had to build my own flange for this creation, as it has a non-standard T3 flange. except im way more partial to low mounting the turbo down low behind the engine, gives way better clearance and options for intakes and you dont have to have such a god damn down pipe. top mounting the turbo is awesome if you wanna run a hood stack... god i love hood stacks.
Reply #418August 31, 2009, 11:19:09 am
53 willys
« Reply #418 on: August 31, 2009, 11:19:09 am »
haha I don't doubt your skills bud..I was just saying it was alot of work... ;)
well I'm kinda opposite of you on the turbo mounting...no hood stack here..but I also wanna be able to get to my turbo stuffing it down low wont help me out any..and I left plenty of room for my next upgrade..I already mocked a 3" dual plane intake just like the PP ones Dave makes...so I got the best of both worlds with this mounting location IMHO 8)
Reply #419August 31, 2009, 11:23:50 am
53 willys
« Reply #419 on: August 31, 2009, 11:23:50 am »
