Author Topic: oil lines for turbo  (Read 1874 times)
September 07, 2008, 07:33:45 am
boosted_diesel_84
  • 216
oil lines for turbo
« on: September 07, 2008, 07:33:45 am »
does anyone have a great idea or source for getting the oil return line from the turbo to the pan on a 1.6td? mine was hacked up and had a piece of rubber hose on it where the braided stainless used to be. also, i will be getting my PP intake next week, will my stock oil feed line be in the way? if so, where can i get braided stainless with the right ends on them?
thanks!!
-Jack-
.0020 over block,balanced,blueprinted,8lb flywheel,Stage 2 clutch,ported and ceramic coated head manifolds,turbo,pistons, SS valves, PP 2.5in DP,Intake, 3" ex.GTD nozzles, Built pump, windage tray,36mm pump,ARP Studs.etc.My build thread http://www.vwdiesel.net/forum/index.php?topic=15461.0
