For Sale/Looking For
Parts for Sale/Wanted
FS AAZ 1.9 td parts, engines, transmissions, etc
Topic: FS AAZ 1.9 td parts, engines, transmissions, etc (Read 11068 times)
September 04, 2008, 04:07:59 pm
houseofdiesel
September 04, 2008, 04:07:59 pm »
So I have come to realize there are too many parts kicking around...
B3/B4 Passat AAZ
-transmission $200 02A cable shift
-flywheel/clutch $50
-a/c compressor $25
-all brackets $10-100 each
-injection pump (DOES NOT have the aneroid boost enrichement, it is there but no way to hook up a line no fitting, all CDN Passats were like this) $150
-p/s pump $40
-injectors $60 set of four
-rebuilt cyl head 1.9 AAZ td (never installed) $500
-1.9 AAZ td block with crank, rods/pistons, intermediate shaft etc has new rings and rod bearings $400
-used AAZ 1.9 block with crank/rods/pistons/intermediate shaft $300
-manifolds with egr function
MK3 Golf and Jetta
-1.9 AAZ block with fixed crank gear (machinist good job) complete with crank/pistons etc $400
-1.9 AAZ crankshaft, polished, tdi crank gear fix $250
-all brackets, valve covers, timing belt covers upper/lower/inside/outside
-clutch and flywheels for 020 trans
-front crossmembers for rad
-subframes for engines
-steering racks, a.c. compressors, manifolds,
I have multiples of pretty much everything, I just cleaned out a friends garage of Vanagon parts need some more space. I will reply however I am busy each night after work putting up more shelves etc to keep it all inside.
Greg
September 05, 2008, 08:10:26 am
shortysclimbin
September 05, 2008, 08:10:26 am »
Greg how much for the front engine mount braket and bolts?
September 05, 2008, 04:14:35 pm
houseofdiesel
September 05, 2008, 04:14:35 pm »
Front engine mount bracket $10 with bolts.
Greg
September 05, 2008, 06:34:17 pm
RabbitGTDguy
September 05, 2008, 06:34:17 pm »
have the IP pump cable assembly for this car (pedal to pump). I'm in need for the b3 mTDI conversion. Thought I had one lined up but haven't heard in a while. Were there any special cruise considerations for the b3 AAZ passats related to the pump? switches, etc? I'd be interested in them as well as the brackets that hold them. If you'd part.
Joe
1972 VW Westfalia
2001 Audi TT 225 Quattro Roadster (something newer
September 07, 2008, 01:50:02 pm
tSoG-84bit
September 07, 2008, 01:50:02 pm »
just curious, but how much for all engine parts and related accessories? no need for A2/3 parts that don't bolt in to A1, or powersteering.
I can pick up so no need for shipping quotes. thanks.
84bit 1.6na
Engine died, pulling it apart, putting something new in it's place.
September 07, 2008, 06:46:43 pm
commuter boy
September 07, 2008, 06:46:43 pm »
B3 Passat air intake to turbo hose for a K14?
September 08, 2008, 01:09:42 pm
houseofdiesel
September 08, 2008, 01:09:42 pm »
I should have the air intake hose, it would really help if you could read the part number off yours though since mine are together on a shelf
I am not sure about the throttle cable from the B3, I think it went onto a conversion car already (gas to diesel). I have to double check what is still on one of the motors tonight
tSoG-84bit just list what you are looking for/need and I will quote you a price, I will try to get some pics up soon to give everyone an idea of how much I have accumulated...
Greg
September 08, 2008, 07:23:37 pm
tSoG-84bit
September 08, 2008, 07:23:37 pm »
I'm interested in blocks, heads and their internals; injection pumps, lines, and injectors; manifolds, turbos. as much as will fit in a pickup truck. Pictures, and a full list/price of what you have would be appreciated, thanks.
84bit 1.6na
September 09, 2008, 08:50:34 am
abnkeis
September 09, 2008, 08:50:34 am »
You have PM
September 09, 2008, 01:45:48 pm
Jet A
September 09, 2008, 01:45:48 pm »
pm'ed on the head
85 vw golf NA ----> 2b TD Daily Driver
Converted to hydraulic head (Thanks zukgod1)
td04 turbo, Zex nitrous (for the big hills), PITA motor, fresh rings w/ ceramic pistons.
Custom Intake and Exhaust
Ported and polished head
Dipricol EGT, FP, Boost,
Autometer, Oil Temp, Water Pressure
September 10, 2008, 07:40:26 am
Chuck S
Newbie
AAZ injectors
September 10, 2008, 07:40:26 am »
Still have 4 for $60? I'll take 'em.
Thanx
Chuck S
Reply #11
September 10, 2008, 05:34:20 pm
RabbitGTDguy
Reply #11 on:
September 10, 2008, 05:34:20 pm »
don't have a AAZ camshaft in good shape do you?
Joe
1972 VW Westfalia
Reply #12
September 10, 2008, 06:11:39 pm
Chuck S
Newbie
Re: AAZ injectors
Reply #12 on:
September 10, 2008, 06:11:39 pm »
Quote from: Chuck S
Arrg!!
I meant to write:
Do you still have 4 AAZ injectors for $60?
I'll take 'em if you do!
Thanx
Chuck S
Reply #13
September 15, 2008, 09:33:06 pm
bigblackcaddy
Newbie
Reply #13 on:
September 15, 2008, 09:33:06 pm »
Is your inbox full? Trying to send you PMs but they're not going through.
Reply #14
September 15, 2008, 10:06:03 pm
starrd
Reply #14 on:
September 15, 2008, 10:06:03 pm »
do you have these items from an AAZ engine?
If so, let me know how much
Thanks
Black 1996 Passat TDI Malone tune, K03/04 Hybrid, Keyless, VR6 Clutch & PP357's
White 1993 Passat TD - GTD nozzles, Keyless - Giles pump, K14, Intercooler, 228mm VR6 clutch & PP, CTN Trans etc
Red 1990 Corrado - custom chip by
