Author Topic: Changing Glow Plugs  (Read 6773 times)
September 01, 2008, 04:05:25 pm
catlin_cava
  • 1954
Changing Glow Plugs
« on: September 01, 2008, 04:05:25 pm »
How hard is it to change the Glow Plugs on a 1.9 TDI in a 2000 Golf?
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #1September 01, 2008, 05:19:27 pm
Slave2School
  • 531
Changing Glow Plugs
« Reply #1 on: September 01, 2008, 05:19:27 pm »
Piece of piss!
Waiting for a bigger better diesel to come along.
2002 ford focme wagon
Reply #2September 01, 2008, 06:48:55 pm
catlin_cava
  • 1954
Changing Glow Plugs
« Reply #2 on: September 01, 2008, 06:48:55 pm »
Do I need any special tools?
Catlin
Reply #3September 01, 2008, 09:03:57 pm
Changing Glow Plugs
« Reply #3 on: September 01, 2008, 09:03:57 pm »
i would imagine it to be slightly easier than on a 1.6 or 1.9aaz due to the fact that the gp harness can simply be unplugged rather than have to be unbolted, and the fact that the injection pump is at an angle to allow access, AND the fact that the glow plugs stick up at an angle, and not pointing straight out.
but then again, theres a bit of extra crap in the way, like the cover... but i'd take that any day over a 1.6 jobber  :lol:
Reply #4September 02, 2008, 08:00:16 am
  • 1739
Changing Glow Plugs
« Reply #4 on: September 02, 2008, 08:00:16 am »
you'll need a 10 mm deep socket and a wooble extenstion would make it easier not to break your new glow plugs. when you put back the buss bar,
make sure it makes a good contact-push them down till you're sure they are on right, otherwise you may get another glow plug DTC.Basically it's a super easy job. Also mae sure they are all the same brand-either bosch or beru, don't mix ,all 4 must be the same.
Reply #5September 04, 2008, 05:50:55 pm
G60ING
  • 170
    Corrado TDI
    • My VW Projects
Changing Glow Plugs
« Reply #5 on: September 04, 2008, 05:50:55 pm »
becarefull with that glowplug harness they tend to get brittle after 6+ years. Odds are you probably need to replace the harness or will have to in a year or so.
If you want to make the job super easy on removing the glowplug harness just remove the hard fuel lines off the injectors.
But the glowplugs themselves are super easy to remove one the harness is off. You just need a 10mm deepwell socket and an extension.
Reply #6September 04, 2008, 06:06:53 pm
Changing Glow Plugs
« Reply #6 on: September 04, 2008, 06:06:53 pm »
nobody seemed to mention that you should... wait...  need to put some anti seize on the threads of the gp's.  this will ensure that the threads don't get wrecked, and that the gp's come out real easy next time they go  :wink:.  remember not to torque them as tight as you would without anti seize.  even though it might feel like it can go more, remember that you need about 20% less torque.
a little conductive grease on the contact end wouldn't hurt either
Reply #7November 13, 2008, 04:04:27 pm
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
Changing Glow Plugs
« Reply #7 on: November 13, 2008, 04:04:27 pm »
i have a 2000 TDI golf that has always gone to the stealership for services. The glow plug light turns off almost instantly when i turn the key to the "on" position. There is no way that they get up to temp in half a second and i recognize that. I checked them all, one was dead - replaced it, but the light still goes off immediately. What is wrong with it the relay? where is the relay?
the check engine light has also come on recently but i knew the glow plug light has been wrong for months. It still starts instantly and only the dead glow plug was sooty.
Is there a common issue with the "check engine light" ? It comes on almost regularly and my parents have always taken it to the stealership for $xxx.xx amounts of money (lots). Any common checks? a particular sensor perhaps? They don't think i can fix anything (even my own IDI TD) and i want to prove them wrong.
this car was made in Germany, not Mexico (if it matters).
Edit: i made a separate thread on this http://vwdiesel.net/phpBB/viewtopic.php?p=123943#123943
Ed
