Author Topic: Glow plug relay question  (Read 2103 times)
August 25, 2008, 07:47:36 pm
silvertdi
  • 125
« on: August 25, 2008, 07:47:36 pm »
What are the symptoms of a faulty glow plug relay?  When my engine is warm the glow plug light will come on and something under the dash starts buzzing...then the coolant temperature starts climbing.  The light and humming will stay on for long periods of time (30 - 45 minutes).  I removed the relay to see what it will do tomorrow.  Anybody experience this before?  Your help is appreciated.
Reply #1August 28, 2008, 08:00:49 pm
silvertdi
  • 125
« Reply #1 on: August 28, 2008, 08:00:49 pm »
I went to start my car this morning and it didn't start.  So I broke open my Bentley manual and went through the glow plug relay diagnostic sequence.  I immediately determined that the glow plug fuse on the firewall had blown.  This was preventing the glow plugs from heating but what caused it to blow?  So I continued with the diagnostic and found that there was no voltage between contacts 85 and 50 when the engine was cranking.  The Bentley says that there is a break in the wire that leads to the 50 terminal.  My guess is that this issue was the cause for the glow plugs coming on while driving and causing the relay to buzz.  So I've got to fix it.  The question is, where does this wire lead too?  I've followed the wire in the manual.  It terminates on wire 15.  Where does wire 15 go?  The manual isn't good about wire terminations.  Can anyone help?
Reply #2August 28, 2008, 08:25:13 pm
monomer
  • 414
« Reply #2 on: August 28, 2008, 08:25:13 pm »
the bentley should have the schematic.
trace it with that
-1983 Rabbit LX 1.6/1.9 VNT build
Michigan Volkswagen Enthusiasts
www.michiganvw.org
Reply #3September 01, 2008, 06:50:08 pm
Duster 5.9
  • 96
« Reply #3 on: September 01, 2008, 06:50:08 pm »
do a contnuity test on your glo plugs to see if there all ok not burnt out. this can happen if the fuse blew. secondly you could of had the relay stay on to long and that blew the fuse. thirdly you could have a short.
81 rabbit gas resting
81 rabbit cabby diesel n/a
85 jetta diesel n/a
85 golf diesel runs great
82 caddy diesel clean
82 caddy gas solid resting
and some parts cars
