Author Topic: electrical problem, maybe  (Read 4118 times)
August 24, 2008, 05:44:09 pm
webman
  • 14
« on: August 24, 2008, 05:44:09 pm »
I am running into a problem.  I replaced the temp sensors for the glow plugs and the temp gauge.  Now the glow plugs are working right, but the gauge in the car is maxing out while I am driving.  The cooling fan is not running at this time, but the fan is working properly.
The engine does not seem overly hot and the coolant is not leaking out.
All fluids are at the proper level.
I am wondering if it might be an electrical problem as I am also having problems with the glow plug light.  It works sometimes.
I have a 91 Jetta with the non-turbo engine.
Reply #1August 24, 2008, 06:35:06 pm
Dirtrag2
  • 298
« Reply #1 on: August 24, 2008, 06:35:06 pm »
for what it's worth Vw electrical isn't the most reliable  :roll:
my 97 jetta does the same ( temp gauge maxes out ) I just slap the dash and it falls back to actual temp
...Darcy
'97 Jetta 1.9TD ( dirtrag2 )
'88 Fox Wagon ( projekt Dirtrag 3 )
Reply #2August 24, 2008, 06:56:55 pm
« Reply #2 on: August 24, 2008, 06:56:55 pm »
i'd say VAG is pretty good... VOA is pretty garbage because its built in mexico with crap grade wires.  they corrode right in the sheathing and turn to green dust!  pretty much all mk3's we have here were built in mexico...
my '92 doesn't have any electrical problems other than the fact the rad fan went and i had to fix someone else's wiring... (the p/o must have thought the wires were bad when it was in fact the fan itself  :roll:)
Reply #3August 24, 2008, 08:02:22 pm
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
« Reply #3 on: August 24, 2008, 08:02:22 pm »
that must be scary watching the dial max out....
thankfully the wireing on these mechanical oil burners is very minimal.
change all the wireing while you're at it? i dunno, maybe ignore me..., i HATE wireing with a passion
Ed
Reply #4August 25, 2008, 03:43:03 pm
webman
  • 14
« Reply #4 on: August 25, 2008, 03:43:03 pm »
Would I see the same problem if the temp sensor is for the wrong car?
Reply #5August 25, 2008, 04:57:44 pm
« Reply #5 on: August 25, 2008, 04:57:44 pm »
personally i'd like everything to go wireless... or just shoot everything through one optical cable & have a little board to process the info... so much bandwidth!!!  :lol:
i think chrysler has gone wireless... it is far superior AND they save on copper  :wink: BUT it leaves area for interference etc...
