Author Topic: intermedate shaft bearings  (Read 2457 times)
August 22, 2008, 12:45:02 am
smiffie88
  • 29
« on: August 22, 2008, 12:45:02 am »
How do i go about putting new bearings back in(shaft that drive the oil pump and vacuum pump) and also where is the best place to get them?
Reply #1August 22, 2008, 05:05:29 am
« Reply #1 on: August 22, 2008, 05:05:29 am »
don't they have to be pressed in? best way would be to dip them in some liquid nitrogen and then press fit them.  but if you don't have any liquid nitrogen, i guess putting them in the freezer will do, as well as heating up the block.  but i dont think you really need to if you have the right tools...
Reply #2August 22, 2008, 08:22:02 am
duffer
  • 164
« Reply #2 on: August 22, 2008, 08:22:02 am »
If you go to another forum
   www.vwdieselparts.com Index
   and do a search on Int. Shaft
   bearings there are anumber
   of posters who have made
   up a variety of home-made
   tools for removal/installation
   of the Int. Shaft bearings.
   Also check out the section on
   home-made tools.
   Hope this helps.
Reply #3August 22, 2008, 08:30:15 am
duffer
  • 164
« Reply #3 on: August 22, 2008, 08:30:15 am »
Sorry, that was the WRONG link
    Go to www.vwdieselparts.com/forum/
    The best bearings are "Clevite" I
    think the number is SH-1209-S. I can
    look that up. They're about $23
    I don't know where you'd get those
    in the U.K., but you can get them
    through www.burnabyauto.com
    They're British Columbia.
    When you're installing the new
    bearings, you have to ensure that
    the oil holes line up and that the
    oil channel in the rear bearing
    points to the vacuum pump gear.
Reply #4August 22, 2008, 12:34:15 pm
Baxter
« Reply #4 on: August 22, 2008, 12:34:15 pm »
I have them for sale.
Not put them on the webshop yet though.
I have KS ones that need machining once installed.
www.brickwerks.co.uk
If you want some then e-mail [email protected] and I'll sort a price, I seem to remember about £12 plus VAT, they ain't expensive!
Reply #5August 23, 2008, 04:03:51 am
smiffie88
  • 29
« Reply #5 on: August 23, 2008, 04:03:51 am »
thanks for the help made a press tool from nylon guess ill just give it ago
