Author Topic: Junk k24 needed  (Read 4418 times)
August 17, 2008, 09:52:01 pm
Junk k24 needed
« on: August 17, 2008, 09:52:01 pm »
Anyone have a junk k24?
I need the shaft/ exhaust wheel to be in good shape and I need the exhaust housing to be goos as well..
Anyone?
Reply #1August 17, 2008, 09:56:06 pm
blkboostedtruck
  • 1535
Junk k24 needed
« Reply #1 on: August 17, 2008, 09:56:06 pm »
Dan that K26 make it too you? pretty bad shape or what?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2August 18, 2008, 07:04:30 am
Junk k24 needed
« Reply #2 on: August 18, 2008, 07:04:30 am »
Quote from: "blkboostedtruck"
Duane
Yes Duane sorry I forgot to let you know.
I've not tore into it yet but ya there is allot of play..
Reply #3August 18, 2008, 07:31:01 am
blkboostedtruck
  • 1535
Junk k24 needed
« Reply #3 on: August 18, 2008, 07:31:01 am »
yea it did! i think that one i sent to karl (saurkraut) was a decent shape K26! it was the other one in the pics. of the one i sent you!
a buddy of mine gave me a nearly new TAO4LA turbo from a PT Cruiser it has the whole manifold attached to the hot side of the turbo like the newer TDI VNTturbo's  i'm gonna cut it off and weld it on a stock N/A VW exhaust manifold! and try that out someday! well the moral to the story here is i can weld cast iron if you ever found a turbo from something else and you wanted to use it on your VW diesel motor!
there's a option for you if you ever decide to go that route?
Duane
'66 variant 1500S
Reply #4August 20, 2008, 10:55:06 pm
westyman
Junk k24 needed
« Reply #4 on: August 20, 2008, 10:55:06 pm »
I have a K24 that had the wastegate actuator removed, valve blocked in the closed position, runs a nice 24 psi wide open on a TD. :-)
Had it on a TD Vanagon, good bearings etc.
Reply #5August 21, 2008, 06:42:33 am
Junk k24 needed
« Reply #5 on: August 21, 2008, 06:42:33 am »
Quote from: "westyman"
What do you need for it?
