Author Topic: turbo oil feed line  (Read 3909 times)
Reply #15August 27, 2008, 08:00:16 pm
turbosuzi
turbo oil feed line
« Reply #15 on: August 27, 2008, 08:00:16 pm »
I installed a transmission oil cooler as the oil cooler for the turbo and used the rubber transmission lines that came with the cooler and they work fine. I had to cut the hard lines out  and fitted the rubber lines on the stubs of the turbo. The rubber transmission lines are rated at 350 psi and are heat tollerant.
