Author Topic: turbo oil feed line  (Read 3888 times)
August 16, 2008, 11:58:02 am
pariah
  • 31
turbo oil feed line
« on: August 16, 2008, 11:58:02 am »
hey its been a while life has been good minus an unexpected clutch job (chance to clean) anyway i flipped the intake flange around to accommodate my intercooler and thought the hard oil line was clear but apparently it wasnt and slowly i wore a small hole in the bugger anyway i solved it by cutting it completely and using some fuel line to make due ... it did a good job and everything even heat shielded it ... am i good to go? or was this a temporary fix ... it did not seem like too much pressure is running through it my Bentley did not say to much on the guy
Reply #1August 16, 2008, 01:28:53 pm
arb
turbo oil feed line
« Reply #1 on: August 16, 2008, 01:28:53 pm »
Where does your feed line get its supply from ? I'm turbo-ing an NA motor...
Reply #2August 16, 2008, 02:09:31 pm
turbo oil feed line
« Reply #2 on: August 16, 2008, 02:09:31 pm »
on top of the oil filter flange.  there should be a port or two that you can unscrew with an allen wrench i believe, and then hook your line up to that.  else you could tee into the oil pressure sensor  :wink:
Reply #3August 16, 2008, 06:19:19 pm
gigaz2
  • 626
turbo oil feed line
« Reply #3 on: August 16, 2008, 06:19:19 pm »
I guess that line sees the full oil pressure, around 8 Bars max (top of my head values)
so, that would be a very temporary fix.
get a new one, or at least use something that endures that kind of pressure/temperatures (hydraulic machinery shops may help you)
Reply #4August 17, 2008, 07:50:51 am
pariah
  • 31
line
« Reply #4 on: August 17, 2008, 07:50:51 am »
arb the supply line runs from the oil cooler to the turbo then from the turbo back to the pan.... ..... can i use a braided stainless line or does it need to be a hard line?
Reply #5August 17, 2008, 11:43:43 am
gigaz2
  • 626
turbo oil feed line
« Reply #5 on: August 17, 2008, 11:43:43 am »
I guess you can use anything that withstands those conditions.
the pipe ref is: 068145771A and costs around 45€ in Europe
Reply #6August 17, 2008, 01:55:39 pm
pariah
  • 31
oil
« Reply #6 on: August 17, 2008, 01:55:39 pm »
sweet thanks for the feedback 8 bar is like 1200 psi thats alot more pressure than i thought ill get it done right ...thanks
Reply #7August 17, 2008, 04:16:32 pm
DieselKraut
  • 54
turbo oil feed line
« Reply #7 on: August 17, 2008, 04:16:32 pm »
8 Bar = 116 Psi
'80 Rabbit 1.5 IDI 126,00Mi Down but not out!
'83 Quantum 1.6 TD IDI
'90 Passat Gasser
Reply #8August 17, 2008, 05:40:13 pm
pariah
  • 31
00ps
« Reply #8 on: August 17, 2008, 05:40:13 pm »
oops extra zero
Reply #9August 17, 2008, 07:51:16 pm
tylernt
  • 344
turbo oil feed line
« Reply #9 on: August 17, 2008, 07:51:16 pm »
Quote from: "jtanguay"
Some oil filter flanges have a convenient bolt. Some only have a boss that would need to be drilled and tapped.
Reply #10August 17, 2008, 09:13:31 pm
arb
turbo oil feed line
« Reply #10 on: August 17, 2008, 09:13:31 pm »
Yeah, for my turbo block - NA engine, I figured where the O.P. sensor was was a greaat place for an oil finter presure / feed line fitting. :-)
For today's welding in S.S. I figure the job I did converting a NA eninge would pending my full description.....
I do have a turbo oil filter / cooler assembly.
Reply #11August 26, 2008, 02:15:56 pm
monomer
  • 414
turbo oil feed line
« Reply #11 on: August 26, 2008, 02:15:56 pm »
anyone have the stock size of the fitting?
what dia. are the lines?
(turboing an N/A here)
www.michiganvw.org
Reply #12August 26, 2008, 03:32:00 pm
turbo oil feed line
« Reply #12 on: August 26, 2008, 03:32:00 pm »
braided steel lines will work just fine.
Reply #13August 26, 2008, 04:23:38 pm
tylernt
  • 344
turbo oil feed line
« Reply #13 on: August 26, 2008, 04:23:38 pm »
Stock tubing size is 8mm OD.
Reply #14August 27, 2008, 06:36:20 pm
dillenger1
  • 777
turbo oil feed line
« Reply #14 on: August 27, 2008, 06:36:20 pm »
does anyone have the id?I have a bunch of stainless tubing i wanna use to fabricate a pipe.I have some 3/8 odwith a 1/4 id and some 1/4 od with and unknown id,but it seems smaller then3/16.
1.6td in toyota pickup
10mm head ,t3 intercooled.
