Author Topic: 1.6L TD in a Dodge Caravan  (Read 234560 times)
Reply #555May 10, 2012, 07:41:51 pm
billybobf
  • 318
    89 golf 1.8 digi, 1.6 na in pieces in the shop
Re: 1.6L TD in a Dodge Caravan
« Reply #555 on: May 10, 2012, 07:41:51 pm »
do you have a drill press?   goodson sells a cool adapter that you can just use your drill press
Reply #556May 10, 2012, 07:45:05 pm
billybobf
  • 318
« Reply #556 on: May 10, 2012, 07:45:05 pm »
http://www.goodson.com/CF-15-150_Diameter_Valve_Spring_Adaptor/
49.99 for this and they seem to work in a drill press,   they sell them in 1.0  1.25 1.5" size   otherwise cheapest they sell is like $200
Reply #557May 10, 2012, 08:50:21 pm
« Reply #557 on: May 10, 2012, 08:50:21 pm »
I made one from a deep socket in less than a 1/2 hour.
Reply #558May 10, 2012, 09:10:20 pm
CrazyAndy
  • 739
« Reply #558 on: May 10, 2012, 09:10:20 pm »
I could see an oxygen sensor socket being used also if you have a 3/8" extension.  use them in the drill press like that tool billybobf mentioned.
Reply #559May 11, 2012, 10:33:48 am
billybobf
  • 318
« Reply #559 on: May 11, 2012, 10:33:48 am »
shoot, an o2 socket and a small 3/8 stud shoved in the back if its not a through hole (or has a smaller hole), as that should fit in even the smallest of drill presses
Reply #560May 11, 2012, 11:13:00 pm
Luckypabst
  • 502
« Reply #560 on: May 11, 2012, 11:13:00 pm »
Yesterday I used my MK1 strut nut tool to pull the valves on a single cylinder Triumph. It worked well enough for a one time thing.
Chris
'82 TD Westy
'81 NA Caddy
Reply #561May 12, 2012, 04:16:20 pm
arb
« Reply #561 on: May 12, 2012, 04:16:20 pm »
Yeah, I have a drill press that I've used on this project over the years, but the 2 axis clamp is a pain to reset once it's removed.... so you convinced me to finish the tool I started to make. :-D
Reply #562May 28, 2012, 10:24:06 am
BlueMule
  • 51
« Reply #562 on: May 28, 2012, 10:24:06 am »
Arb, these are the folks I buy my VW and Porsche tools from, you can get the pieces separate, or maybe just get the adapter and use something to compress the spring.
http://www.baumtools.com/search/index.php
#s 2036, 541/5 and 541/1 I believe these are the ones you want, but call to be sure.
BlueMule
BlueMule
A.S.E. Master Since 1986
Nissan Master Since 1995
Auto Tech Since 1975
Totally Ignorant When It Comes To MY
'86 Golf TD
Reply #563May 28, 2012, 04:57:25 pm
arb
« Reply #563 on: May 28, 2012, 04:57:25 pm »
Thanks BlueMule...  this will help. Said teen age son is not quite out of school yet so I have not cornered him in the shop yet...
