Author Topic: have i got a seat engine?  (Read 8287 times)
Reply #15August 10, 2008, 08:09:22 am
« Reply #15 on: August 10, 2008, 08:09:22 am »
Corners look too square to fit.
Reply #16August 10, 2008, 10:06:12 am
blkboostedtruck
  • 1535
« Reply #16 on: August 10, 2008, 10:06:12 am »
Quote from: "Kudagra"
I wonder if this valve cover would fit...
http://cgi.ebay.com/VW-Polo-G40-Alu-Ventildeckel_W0QQitemZ180274745102QQcmdZViewItem?hash=item180274745102&_trkparms=72%3A635%7C39%3A1%7C66%3A4%7C65%3A12&_trksid=p3286.c0.m14.l1318
that G40 cover will not work on a 1.6 nor a 1.9 because both ends have a half moon cut out like the pully side on the 1.6 and 1.9 does
 a G60 cover will work on a 1.9 the head would have to be drilled and taped in 8 spots and all the center studs removed hope that helps you guys?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #17August 12, 2008, 05:57:26 am
snakemaster
  • 405
« Reply #17 on: August 12, 2008, 05:57:26 am »
1.9 idi  had on in my mk2 golf for a while , i don the gov mod adv pump and turnd up the max fuel screw , and it would take std 1.6 td idis , the best thing in that engine is the inlet manfold
