Author Topic: Stuck cv bolts  (Read 5972 times)
August 06, 2008, 11:35:45 am
Kantdrivefast
  • 196
Stuck cv bolts
« on: August 06, 2008, 11:35:45 am »
So the jetta has been sitting in the yard with two stuck cv bolts. to make matters worse, theyre stripped. Ive tried cutting one in two but theres not alot of room to work with and the bottom of the car is covered in alot of oil. Any tips/tricks on getting em out
Cas
Reply #1August 06, 2008, 12:12:16 pm
blkboostedtruck
  • 1535
Stuck cv bolts
« Reply #1 on: August 06, 2008, 12:12:16 pm »
iv'e gotten some stubborn one's with visegrips plyers!
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2August 06, 2008, 12:53:24 pm
gigaz2
  • 626
Stuck cv bolts
« Reply #2 on: August 06, 2008, 12:53:24 pm »
first apply degreaser and wash the area, then try the visegrips as Blkboostedtruck said, working in a dirty environment is half way to injuries.
Reply #3August 06, 2008, 12:54:15 pm
Stuck cv bolts
« Reply #3 on: August 06, 2008, 12:54:15 pm »
I've cut the head off then you can get a good grip with vise grips.
"edit"
let me clarify. Once you cut hte heads off the bolts you can remove the axle leaving the stuck bolts in the flange.
I've used a flame wrench as well to heat the part the axle bolts to (flange).
Got one to hot once and ended up replacing the out put seal :(
Reply #4August 06, 2008, 01:11:19 pm
Kantdrivefast
  • 196
Stuck cv bolts
« Reply #4 on: August 06, 2008, 01:11:19 pm »
ive tried the vice grips on the bolts Ive cleaned up. Several failed attempts. I hate resorting to cutting the bolt heads off but if its what I must do...
Thanks for the help
CAs
Reply #5August 06, 2008, 03:54:33 pm
Stuck cv bolts
« Reply #5 on: August 06, 2008, 03:54:33 pm »
Cut the heads clean off and then you will be able to unscrew them with your fingers. Once you actually get the axle off of course
Reply #6August 06, 2008, 05:59:45 pm
Kantdrivefast
  • 196
Stuck cv bolts
« Reply #6 on: August 06, 2008, 05:59:45 pm »
done, new bolts are on the way!
Reply #7September 08, 2008, 02:20:25 am
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
Stuck cv bolts
« Reply #7 on: September 08, 2008, 02:20:25 am »
for search purposes:
I had this problem with the alan head bolts that hold the disk calipers together. Someone previously had stripped them into perfect circles. I hammered a torques socket onto them and put a breaker bar on that. That worked wonders! Getting the bolt out of the socket is a little tricky though.
Ed
Reply #8October 20, 2008, 02:14:47 pm
smutts
  • 720
    ClackClackClackClackClack
Stuck cv bolts
« Reply #8 on: October 20, 2008, 02:14:47 pm »
I hate these things. Is there a bihex alternative out there? :?
Reply #9October 20, 2008, 03:13:55 pm
Stuck cv bolts
« Reply #9 on: October 20, 2008, 03:13:55 pm »
I'm sure there is.
Probably just a standard Metric thread.
Reply #10January 12, 2009, 05:17:49 am
regcheeseman
  • 714
Stuck cv bolts
« Reply #10 on: January 12, 2009, 05:17:49 am »
Cold chisel and hammer.
100% guaranteed solution.
One good belt end-on will shock the bolt free.
then just tap it round with chisel and hammer
Reply #11January 12, 2009, 09:10:53 pm
AdAm84
Stuck cv bolts
« Reply #11 on: January 12, 2009, 09:10:53 pm »
I replaced all of my bolts with allen bolts from my local hardware store. Seem to hold up just fine as i replaced them over two years ago. Cheap too  :)
Reply #12January 14, 2009, 02:22:13 pm
smutts
  • 720
Stuck cv bolts
« Reply #12 on: January 14, 2009, 02:22:13 pm »
KILL THEM ALL!
By the way, did I say that I hate these things? :evil:
Reply #13January 14, 2009, 04:26:07 pm
Stuck cv bolts
« Reply #13 on: January 14, 2009, 04:26:07 pm »
I'll take a 12pt over a 6pt any day
Reply #14January 14, 2009, 08:41:59 pm
Kantdrivefast
  • 196
Stuck cv bolts
« Reply #14 on: January 14, 2009, 08:41:59 pm »
Quote from: "zukgod1"
I'm sure there is.
yup, thats what I put in the one cv
CAs
