Author Topic: cam belt wear  (Read 2568 times)
August 05, 2008, 02:33:29 pm
max and caddy
  • 7
cam belt wear
« on: August 05, 2008, 02:33:29 pm »
hi, anybody had any issues with the cambelt "walking" of the sides of the pulleys? mine is doing it and is fluffing up on the tensioner pulley and slowly wearing down the belt, i just changed the ip and its mounting console but still it does it. any ideas?
Reply #1August 05, 2008, 02:50:54 pm
gigaz2
  • 626
cam belt wear
« Reply #1 on: August 05, 2008, 02:50:54 pm »
yes, somebody had that problem, can't remember exactly, but you can have a crooked pulley as well, have you tested for that?
Reply #2August 05, 2008, 03:10:01 pm
cam belt wear
« Reply #2 on: August 05, 2008, 03:10:01 pm »
If you just took the pump off as well as the mounting for it and you didn't have this problem before your IP mounting is probably cocked, or the new IP you put on has worn bearings and it running on an angle
Reply #3August 05, 2008, 03:32:10 pm
Turbinepowered
  • 1206
cam belt wear
« Reply #3 on: August 05, 2008, 03:32:10 pm »
The other possibility is the "brace" bracket, that sits behind the IP and is bolted to the block and the IP mounting plate, might not be sitting properly.
Someone linked a TSB that said if you have alignment problems, loosen the bolts holding that brace, push the front (IP plate side) up and the back side down, then retighten.
If you never took that particular brace off, might not be your problem though. My misalignment ultimately was because I had a bent IP bracket.
Reply #4August 05, 2008, 05:02:55 pm
CoolAirVw
  • 175
cam belt wear
« Reply #4 on: August 05, 2008, 05:02:55 pm »
85 Jetta Turbo Diesel
75 Porsche 914
93 GMC Truck
99 Caravan <--wifes gotta drive something :)
Reply #5August 05, 2008, 08:02:18 pm
Possum79
  • 276
    • http://www.poscarclub.com
cam belt wear
« Reply #5 on: August 05, 2008, 08:02:18 pm »
http://www.poscarclub.com/vw_stuff/timing_belt_alignment.pdf
I found the service bulleting on my computer so I did have it and I added uploaded to my server.
There you go for anyone who wants it.
~Ryan
1979 VW Rabbit Diesel L
My car may be ugly but im addicted to it.
Reply #6August 06, 2008, 10:42:48 am
max and caddy
  • 7
cam belt wear
« Reply #6 on: August 06, 2008, 10:42:48 am »
cheers for the info, its kinda what i was expecting really, i changed my AAZ pump for a 1.6 one and i changed the cast mounting brack also because it is different between the cable cold start pump and the electronic advance one it replaced, the belt run off with both pumps but i will try takin it off AGAIN to sort it. thanks for the link to the vw bulletin mate!
Reply #7August 06, 2008, 11:12:59 am
max and caddy
  • 7
cam belt wear
« Reply #7 on: August 06, 2008, 11:12:59 am »
just one more thing tho, if my pump had worn bearings it would tip the center shaft the same way as if i adjusted the bracket as per the bulletin! odd?
Reply #8August 06, 2008, 03:14:19 pm
max and caddy
  • 7
cam belt wear
« Reply #8 on: August 06, 2008, 03:14:19 pm »
well i spent the evening outside in the rain tinkering with the pump bracket as per the vw bulletin and sucsess! its fixed! cheers peeps.
Reply #9August 06, 2008, 03:53:25 pm
cam belt wear
« Reply #9 on: August 06, 2008, 03:53:25 pm »
Glad to hear
