General Information
Troubleshooting
garett turbo question
Topic: garett turbo question (Read 4654 times)
August 04, 2008, 01:49:37 pm
A Guy
August 04, 2008, 01:49:37 pm »
Finally got around to installing a boost controller(manual) on my 1.9 golf w/gilles pump and 2.25 exhaust. when we hooked it up we were expecting to see a reading around 6-8 psi as the turbo ahs always seemed non existent but it was reading 12psi! Is it normal the w/this much psi you wouldn't notice the turbo let alone hear it? What is the engine capable of handling. head gastket new belts new etc etc. I was thinking as long as we kept it under 20psi we should be fine. advise and recomendations are very much appreciated/
out.
Greg
August 04, 2008, 02:55:52 pm
August 04, 2008, 02:55:52 pm »
Try taking the boot off the turbo then go for a drive, I'll bet you notice it then. Or the lack of it at least.
I don't hear mine until about 15 psi. I can hear it while idling if I'm standing behind it but that's it, till she's wound up nothing.
August 06, 2008, 11:11:31 am
91 ECO
August 06, 2008, 11:11:31 am »
My K14 is quiet even with the 2.5" downpipe and exhaust. The only time I hear it is when I drive by something that will reflect the sound of the car (side of a building). I only run about 10psi. Like zuk said, try disconnecting something like the line from the manifold to the LDA and I'm sure you will notice the lack of boost. I tried it one day just goofing off and it reminded me of my pre-giles eco.
September 06, 2008, 12:01:46 pm
September 06, 2008, 12:01:46 pm »
with stock dp and exhaust i can hear mine garett t3 spooling about as loud as the engine at only .... 5-8 psi? and wirring pleasantly at 10
Blue 2009 CR140 Jetta CBEA/CJAA. Malone stage 2. EGR/DPF/Exhaust-valve deletes. 2.5" open exhaust. ADP Turbo swap. 1-stage nitrous kit.
THROWN ROD
September 07, 2008, 03:55:04 pm
dillenger1
September 07, 2008, 03:55:04 pm »
when my t3 is idling i hear it whisping when i blip the throttle it lets is presents be known.Its is about as load as the engine.a tad quieter
1.6td in toyota pickup
10mm head ,t3 intercooled.
September 10, 2008, 07:54:51 am
g-spec
September 10, 2008, 07:54:51 am »
I have a T3 on my car with stock exhaust and a cone filter. (Car came with no intake when I bought it). I could hear the turbo at 10psi. Now im running 30 and I can hear it spooling with getting on it. Still have to remove a few things from the exhaust.
September 10, 2008, 07:58:31 pm
VelocityConservation
September 10, 2008, 07:58:31 pm »
I have a K-24, PP downpipe and 2.25" through to a high flow muffler.
I can hear the turbo at idle and striaght up to the 12psi when the waste gate opens.
90 TD Jetta, NA to TD swap completed '07
General Information
Troubleshooting
