Author Topic: Replacing injector pump and how to set timing on 1.6 N/A  (Read 4224 times)
July 28, 2008, 01:37:44 pm
81caddy
« on: July 28, 2008, 01:37:44 pm »
I just replaced my injector pump and feel the I do not have the timing right.  I bought the timing belt tool kit from dieselvw. com which helps, but I don't know if I am using the dial indicator right.  The dial indicator is in standard and the specifications are in metric, however I converted all the numbers properly.
I did get my engine to start, but it did not run very well.  When I push the accelerator nothing really happens.  The rpms don't go up, nothing happens.  The cable is adjusted correctly, I can see it moving the lever on the injector pump.
I don't if anyone has any tips for me.  Anything would be helpful.
Thank you.......
Reply #1July 28, 2008, 03:51:12 pm
« Reply #1 on: July 28, 2008, 03:51:12 pm »
How long have you been running it for? If there is lots of air left in it it will run like that.
Check the FAQ for a post by Vince about pimping your glowplugs. On his site he has step by step timing
Reply #2July 28, 2008, 03:54:09 pm
81caddy
« Reply #2 on: July 28, 2008, 03:54:09 pm »
I ran the engine for about five minutes.  I would think all the air bubbles would be out of the lines by then.
Reply #3July 28, 2008, 09:57:29 pm
« Reply #3 on: July 28, 2008, 09:57:29 pm »
In case the search function brings someone to this thread some day looking for some additional info on setting the timing:
http://vincewaldon.com/index.php?option=com_content&task=view&id=24&Itemid=28
Reply #4July 29, 2008, 04:29:07 am
« Reply #4 on: July 29, 2008, 04:29:07 am »
Quote from: "81caddy"
Yes most likely, unless you had an air leak allowing lots of air back into the system
