Author Topic: Idle Boost w/ A/C?  (Read 2352 times)
July 23, 2008, 09:28:54 am
Jettage1
  • 202
    Past VWs: 80 Scirocco S, 90 GTI, 00 Passat GLX
Idle Boost w/ A/C?
« on: July 23, 2008, 09:28:54 am »
I'm noticing that the idle on my ECO seems rather low when the A/C is on.  It is fine otherwise.  Is there any downside to pulling out the dash lever just a bit to kick the idle up when the A/C is on (especially for stop & go, not hwy driving)?  IIRC, that advances timing??
It doesn't usually die, although I have had at least one instance of putting in the clutch to make a right hander and the combination of the steering and the A/C managed to kill it.
Thanks in advance (pun intended)...
Steve
92 Jetta EcoDiesel
     pumped by Giles...powered by Frybrid...functional by dumb luck
Reply #1July 23, 2008, 09:37:56 am
Idle Boost w/ A/C?
« Reply #1 on: July 23, 2008, 09:37:56 am »
No problem at all, pull that suka out..
Reply #2July 23, 2008, 11:30:30 am
Darth Garry
  • 136
    • http://www.notinteresting.com
Idle Boost w/ A/C?
« Reply #2 on: July 23, 2008, 11:30:30 am »
Get rid of the power steering :)
Honestly, I was thinking the same thing, it is very boggy when running with the AC.
Garry
All for one, and one for Awesomeness!
Reply #3July 23, 2008, 01:19:12 pm
burnt_servo
  • 278
Idle Boost w/ A/C?
« Reply #3 on: July 23, 2008, 01:19:12 pm »
i've had my car close to 5 years , and i've been pulling out the fast idle lever since i bought it , when the ac is running , with no problems .
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #4July 23, 2008, 02:59:20 pm
Darth Garry
  • 136
Idle Boost w/ A/C?
« Reply #4 on: July 23, 2008, 02:59:20 pm »
Are you referring to the timing advance lever?
Garry
Reply #5July 23, 2008, 03:10:15 pm
Idle Boost w/ A/C?
« Reply #5 on: July 23, 2008, 03:10:15 pm »
it only increases timing till about 1800, then the natural timing advance takes over.
louder idle is all you'll experience, and possibly higher fuel consumption.
Reply #6July 23, 2008, 06:48:15 pm
Jettage1
  • 202
Idle Boost w/ A/C?
« Reply #6 on: July 23, 2008, 06:48:15 pm »
Thanks for all of the input.  Sounds like I have my answer...  I agree it probably leads to a bit worse mileage, but then so does running the A/C.  Anyway, running the A/C is always a calculated risk - you have to decide which you want more - dry armpits or half the world up your backside 'cause you're accelerating at...no, wait.  You can't legitimately call it acceleration... :shock:
Steve
92 Jetta EcoDiesel
