General Information
Troubleshooting
Still leaking oil
Topic: Still leaking oil (Read 6829 times)
July 21, 2008, 09:15:10 pm
Still leaking oil
July 21, 2008, 09:15:10 pm »
After a new rear main, I still seem to be leaking a decent amount of oil. It never did this before the engine ran away. I don't seem to have hardly any blowby and when running with the tranny out, the flywheel seemed to be running smooth, so it didn't seem like a bent crank. Any other thoughts? this leak is starting to piss me off. :evil:
July 21, 2008, 09:43:56 pm
Dakotakid
Still leaking oil
July 21, 2008, 09:43:56 pm »
The 15.5 mm oil galley plug dislodged???
July 21, 2008, 10:07:26 pm
Still leaking oil
July 21, 2008, 10:07:26 pm »
Where is it, on the back of the block? My adapter is sealed around the seal, and from what I can tell, the oil leahs out between the adapter and tranny, so it has to be coming from the rear main or there about.
July 22, 2008, 10:13:16 am
smutts
ClackClackClackClackClack
Still leaking oil
July 22, 2008, 10:13:16 am »
If I remember right, there is a core pluggy thing covered up when the bellhosing bolts up. About six inches above the starter motor position. I used to think what a dumb place to put a coolant core plug, but apparently it's for the oil gallery.
July 22, 2008, 11:27:35 am
rallydiesel
Still leaking oil
July 22, 2008, 11:27:35 am »
That's the plug for getting at the intermediate shaft. I feel for jimfoo. :cry:
1991 Jetta TD - sold
2001 Golf TDI - Son's
July 22, 2008, 08:54:49 pm
Dakotakid
Still leaking oil
July 22, 2008, 08:54:49 pm »
There is also the small oil galley plug on my N/A blocks. Machine shop removed to make sure the passage will flow...........Charlie (me) got to take engine in and out 3 times before they got the right plug back in.
I eventually got $250 bucks back out of them....only because the shop foreman wanted an old dirt bike I have. For awhile there...I was so angry I could not talk!
July 22, 2008, 10:14:13 pm
Still leaking oil
July 22, 2008, 10:14:13 pm »
I had a leaky o-ring around the vacuum pump,.. with the block tilted back the oil would leak down between the tin sheild and block.
Everything leaking down the front of the block into this area will come out by the bottom of the trany.
July 22, 2008, 10:18:45 pm
Still leaking oil
July 22, 2008, 10:18:45 pm »
I think I will wash the crap out of the engine, drive upo something steep, park it and crawl underneath to see exactly where it is coming from, there is so much oil everywhere it may not be coming from the drain hole in the bell housing.
July 22, 2008, 10:40:45 pm
Powered by Spearco
Still leaking oil
July 22, 2008, 10:40:45 pm »
I'm going out on a limb here, but has the lip of the rear main seal worn the end of the crank enough to not seal it anymore. :roll:
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
July 23, 2008, 06:43:54 am
Still leaking oil
July 23, 2008, 06:43:54 am »
Good thought, but the crank was totally smooth, no groove at all. I will give everything a good look over today. I really hate marking my territory, especially when in places like this.
July 23, 2008, 08:13:39 pm
CoolAirVw
Still leaking oil
July 23, 2008, 08:13:39 pm »
I pulled my trans looking for a rear main leak shortly after building my motor. I saw nothing wrong so I put it back in and found the pressure gauge that I was using on the oil pressure hole on the back of the head was leaking down into the bellhousing! Duuh!
85 Jetta Turbo Diesel
75 Porsche 914
93 GMC Truck
99 Caravan <--wifes gotta drive something
Reply #11
July 23, 2008, 08:21:25 pm
Powered by Spearco
Still leaking oil
Reply #11 on:
July 23, 2008, 08:21:25 pm »
Could it be the trans input shaft seal thats leaking? :roll:
'13 Golf R:. Tuned
'98 Puch G320
Reply #12
July 23, 2008, 08:33:05 pm
Still leaking oil
Reply #12 on:
July 23, 2008, 08:33:05 pm »
Quote from: "Powered by Spearco"
This is where mine was leaking, ended up being that tiny little seal where the release rod slides through the input shaft. That wont help jimfoo as he isn't using that trans but hey...
Reply #13
July 24, 2008, 07:12:45 am
Still leaking oil
Reply #13 on:
July 24, 2008, 07:12:45 am »
Hehe, there is unfortunately no such seal on my transmission, though I am working on my own solution to that design flaw. I did find a slightly loose clamp on the hose from the turbo, just to the side of the valve cover. There was some oil under it. My turbo does leak oil, though I had hoped not that much. Also one of the hydraulic hoses from the remote filter adapter leaks a little. I'm starting to think between the two of them, oil gets blown back onto the bellhousing making it look like it's the culprit. I wiped it clean, drove up a steep pile of dirt, and no oil was coming out the bellhousing drain, which it would be doing if it was the rear main. VC gasket seems good as well. It only seems to drip after driving it for a while.
Reply #14
July 25, 2008, 11:50:31 am
Still leaking oil
Reply #14 on:
July 25, 2008, 11:50:31 am »
Yeah, turbo is pushing a lot of oil. After tightening the clamp I'm smoking like a mother. May now have a boost leak somewhere else as I can barely make 12 psi. Turbo coming off.... :evil:
General Information
Troubleshooting
Still leaking oil
