Author Topic: throttle sticking, something with the ip  (Read 2058 times)
July 14, 2008, 07:55:38 pm
« on: July 14, 2008, 07:55:38 pm »
so the throttle is sticking in the pump, iam pretty brain dead as far as the pumps, but its not a run away or anything, and its not the cable. i pulled the cable off and moved the lever and sticks like that as well, has anyone else had this problem?  how did they solve it?
Reply #1July 14, 2008, 08:37:24 pm
dieseldunebuggy
  • 24
« Reply #1 on: July 14, 2008, 08:37:24 pm »
I had this problem once, all I did was spray some WD40 around the throttle shaft. I haven't had the problem since. Hope this helps.
1981 Volkswagen Rabbit L custom 1.6l N/A
-Stainless Steel Header
-Huge Custom Intake
-Ported Head
-Lightened Flywheel
-ARP Headstuds
-GILES PUMP
Reply #2July 14, 2008, 08:55:39 pm
Op-Ivy
  • 513
« Reply #2 on: July 14, 2008, 08:55:39 pm »
Check to see if the springs are binding too. Sometimes they can cause the shaft to move slowly or even get stuck. WD40 on those might help as well.
Reply #3July 15, 2008, 06:19:51 pm
« Reply #3 on: July 15, 2008, 06:19:51 pm »
yeah it was just the springs, i sprayed some lube on and now it feels weird to drive because it takes so little effort to depress the gas pedal
