Author Topic: Lines running from Vacuum Pump Check Valve on 95 Jetta  (Read 2084 times)
July 09, 2008, 03:21:12 pm
homerj1
  • 433
« on: July 09, 2008, 03:21:12 pm »
As the subject suggests, I have two vac. lines that are connected to the vac. pump check valve. One in green, the other is a light brown in color.
What do they do & do they need to be connected to vacuum?
Thanks
Aivars
Reply #1July 09, 2008, 03:51:28 pm
« Reply #1 on: July 09, 2008, 03:51:28 pm »
On that vintage AAZ the most likely candidates are:
1) to the cruise control.. on my beast that's the green hose
2) to a solenoid valve mounted on the passenger side strut tower, which then leads to a black vacuum idle actuator mounted on the injection pump:
On my car that one was light brown.  Its purpose is to up the idle... either due to the air conditioning being on or cold temps... prehaps both ?  Dunno for sure because the wiring to the solenoid valve was disconnected on my beast and I deleted all the vacuum stuff hanging off the pump.
BTW... on some MK3s the cruise control has its own vacuum pump, so your mileage may vary ;-)
Reply #2July 11, 2008, 09:45:46 am
homerj1
  • 433
« Reply #2 on: July 11, 2008, 09:45:46 am »
Once again Vince, thanks!
Aivars
Reply #3July 12, 2008, 08:06:38 am
Tintin
  • 1279
« Reply #3 on: July 12, 2008, 08:06:38 am »
If your car are equipped with the K03 turbo, there are a vacuum device acting on the turbo actuator to keep the wastegate open from 0 to around 1/4 throttle,  if not you get 10-15 psi of boost in light load normal driving (too small turbo)
