Author Topic: turbo oil line??  (Read 4480 times)
July 06, 2008, 09:08:00 am
Hammy
  • 169
turbo oil line??
« on: July 06, 2008, 09:08:00 am »
Has anyone fabbed their own steel line or flex line from the oil filter housing to the turbo? If so, what size is that line (diameter), or am I just stuck with having to buy an original oem?
Thanks in advance.
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
'98 GMC 1500 4x4, 5.7L (doing my best to save the oil companies, 85 liters takes me 600 km)
'78 Ford 3000 3cyl, 201 diesel, with loader
Reply #1July 06, 2008, 09:48:19 am
turbo oil line??
« Reply #1 on: July 06, 2008, 09:48:19 am »
I have seen places that sell generic steel braded line to make your own. Stock are somewhere around 1/4" ish, maybe a bit bigger.
Reply #2July 06, 2008, 10:03:17 am
Hammy
  • 169
turbo oil line??
« Reply #2 on: July 06, 2008, 10:03:17 am »
I guess they are metric fitting though?
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
Reply #3July 06, 2008, 04:15:49 pm
homerj1
  • 433
turbo oil line??
« Reply #3 on: July 06, 2008, 04:15:49 pm »
I was told OEM was $70 from the dealer.
 Mine had a pinhole & was leaking - I tried to replace the broken part with compression fitting, but couldn't find any that fit - as the line seems thicken then most. I was also going to use auto. trans. rubber line, which is good to 300 psi.
But ended up scoring a used one, but thought the trans. line might of worked?
Aivars
Reply #4July 06, 2008, 07:40:45 pm
Hammy
  • 169
turbo oil line??
« Reply #4 on: July 06, 2008, 07:40:45 pm »
I managed to score a used one. Looked like new. So, thanks for the help everyone. I still wouldn't mind making a flexible unit though.
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
