General Information
Troubleshooting
turbo oil line??
Topic: turbo oil line?? (Read 4492 times)
July 06, 2008, 09:08:00 am
Hammy
turbo oil line??
July 06, 2008, 09:08:00 am »
Has anyone fabbed their own steel line or flex line from the oil filter housing to the turbo? If so, what size is that line (diameter), or am I just stuck with having to buy an original oem?
Thanks in advance.
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
'98 GMC 1500 4x4, 5.7L (doing my best to save the oil companies, 85 liters takes me 600 km)
'78 Ford 3000 3cyl, 201 diesel, with loader
July 06, 2008, 09:48:19 am
turbo oil line??
July 06, 2008, 09:48:19 am »
I have seen places that sell generic steel braded line to make your own. Stock are somewhere around 1/4" ish, maybe a bit bigger.
July 06, 2008, 10:03:17 am
Hammy
turbo oil line??
July 06, 2008, 10:03:17 am »
I guess they are metric fitting though?
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
July 06, 2008, 04:15:49 pm
homerj1
turbo oil line??
July 06, 2008, 04:15:49 pm »
I was told OEM was $70 from the dealer.
Mine had a pinhole & was leaking - I tried to replace the broken part with compression fitting, but couldn't find any that fit - as the line seems thicken then most. I was also going to use auto. trans. rubber line, which is good to 300 psi.
But ended up scoring a used one, but thought the trans. line might of worked?
Aivars
July 06, 2008, 07:40:45 pm
Hammy
turbo oil line??
July 06, 2008, 07:40:45 pm »
I managed to score a used one. Looked like new. So, thanks for the help everyone. I still wouldn't mind making a flexible unit though.
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
General Information
Troubleshooting
turbo oil line??
