Author Topic: 1.9 "ECO" diesel?  (Read 4494 times)
July 01, 2008, 09:22:46 pm
Wayland
  • 364
1.9 "ECO" diesel?
« on: July 01, 2008, 09:22:46 pm »
Wondering if there's such a thing as a 1.9 ECO diesel? I just bought a 93 Passat 1.9 TD, and the IP has the lower part of the LDA, but the top is capped off with a flat plate, and no line to the intake manifold.  It's obviously factory, not a hack.
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
Reply #1July 01, 2008, 09:33:57 pm
Re: 1.9 "ECO" diesel?
« Reply #1 on: July 01, 2008, 09:33:57 pm »
Quote from: "Wayland"
Kinda looks like this ??
That would be the ECO AAZ... I believe only on early Passats.  Got one of those pumps myself by mistake.... evidently none of the LDA guts are there under the cap.
Reply #2July 01, 2008, 09:38:42 pm
Wayland
  • 364
1.9 "ECO" diesel?
« Reply #2 on: July 01, 2008, 09:38:42 pm »
Thanks for posting the pic. That's the one, alright.
93 Dodge CTD Truck
Reply #3July 18, 2008, 09:27:50 pm
neimis
  • 75
1.9 "ECO" diesel?
« Reply #3 on: July 18, 2008, 09:27:50 pm »
The non LDA (flat top) pump is the stock pump that came on my 92 Passat TD. It also has the EGR, so that means it's an ECO diesel. I thought that all the B3 diesel Passats in Canada were equipped this way.
I like my new LDA "Giles" pump, by the way. A lot.
'92 Passat TD
'01 Golf TDI
'15 Golf TDI
Reply #4July 19, 2008, 01:36:17 pm
Wayland
  • 364
1.9 "ECO" diesel?
« Reply #4 on: July 19, 2008, 01:36:17 pm »
This seems to be the case. I just looked at another 93 Passat for sale, and it was an ECO too.
93 Dodge CTD Truck
Reply #5September 10, 2008, 01:41:11 pm
regcheeseman
  • 714
1.9 "ECO" diesel?
« Reply #5 on: September 10, 2008, 01:41:11 pm »
My AAZ I believe to be an ECO - it has gas recirc and the tiny turbo but the pump has a LDA. the boost pin has a flat profile and there is no preload screw on the top of the LDA.
Is it an ECO? has it got the 9mm head?
Reply #6September 10, 2008, 06:30:08 pm
1.9 "ECO" diesel?
« Reply #6 on: September 10, 2008, 06:30:08 pm »
regcheeseman yours does not sound like an ECO.
Not all passats had EGRs, most did though.
Reply #7September 13, 2008, 02:46:29 pm
regcheeseman
  • 714
1.9 "ECO" diesel?
« Reply #7 on: September 13, 2008, 02:46:29 pm »
drives like one though. :(
revving it just makes more noise - no real increase in speed!
600 miles on a tank though  :lol:
Reply #8September 15, 2008, 06:52:42 am
4KTD
1.9 "ECO" diesel?
« Reply #8 on: September 15, 2008, 06:52:42 am »
I just got a pump like this.  It has a vacuum advance as well. Does anyone know if it has an 8 or 9mm plunger?
Reply #9September 15, 2008, 07:25:45 am
MJF
  • 581
1.9 "ECO" diesel?
« Reply #9 on: September 15, 2008, 07:25:45 am »
You could check it from pump number. 0 460 494 xxx is 9mm and 0 460 484 xxx is 8mm.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #10September 15, 2008, 09:35:28 am
4KTD
1.9 "ECO" diesel?
« Reply #10 on: September 15, 2008, 09:35:28 am »
Well the good new is that my pump has a 9mm plunger but when I opened the LDA plate there is nothing there. I will have to replace the whole LDA to get the boost pin in there.  Does anyone know what the vacuum advance connects to (on the Passat TD)?
Reply #11September 15, 2008, 09:45:13 am
1.9 "ECO" diesel?
« Reply #11 on: September 15, 2008, 09:45:13 am »
Quote from: "4KTD"
Its purpose is to up the idle slightly when the A/C is on... a solenoid valve driven by the Fan Control Module (iirc)  applies vacuum from a tee off the vacuum pump.  The solenoid came disconnected on mine, but I traced the schematic one day and I believe it goes back to the FCM.
Reply #12September 15, 2008, 09:54:06 am
4KTD
1.9 "ECO" diesel?
« Reply #12 on: September 15, 2008, 09:54:06 am »
Quote from: "Vincent Waldon"
So does it just increace idle or advance the timing?
Reply #13September 15, 2008, 09:56:59 am
1.9 "ECO" diesel?
« Reply #13 on: September 15, 2008, 09:56:59 am »
Idle... it's pulling on a throttle linkage.
On the 1.6 cars that are so equipped this same linkage is tugged by the cold start handle at the second notch while a different linkage advances the timing on notch 1 and 2.
