So I did the smog mod, should it puff smoke if I rev at idle
Topic: So I did the smog mod, should it puff smoke if I rev at idle (Read 3588 times)
May 12, 2005, 09:21:43 pm
Topherdiesel
May 12, 2005, 09:21:43 pm »
Did the mods, more fuel and such, notice she puffs a little if revved at idle?
Is this normal?
May 13, 2005, 08:16:52 am
acidwarp
May 13, 2005, 08:16:52 am »
too much fuel = too much smoke = too much high temperature....not good!
May 13, 2005, 08:16:56 am
DVST8R
May 13, 2005, 08:16:56 am »
Yes
The Brett of the board...
The Dark Side of Beauty.
[/i]
May 13, 2005, 08:27:25 am
Topherdiesel
May 13, 2005, 08:27:25 am »
Well, which one is it?
May 13, 2005, 09:13:52 am
acidwarp
May 13, 2005, 09:13:52 am »
at step 3, it says to turn the screw of the max fueling adjuster, its probably that step where you maybe turned the screw too much..
May 13, 2005, 10:18:21 am
shox75
Smoke equals running rich...
May 13, 2005, 10:18:21 am »
I would back the fueling screw off to the least smoke, or no smoke at all depending on the age of the engine if that at all possible.
Sabi Szilagyi
'90 Jetta TD
