Author Topic: presentation and doubts - RECOVERED  (Read 2639 times)
June 20, 2008, 07:16:12 am
« on: June 20, 2008, 07:16:12 am »
I accidently deleted your post doing a batch porn delete.
I spoke with Marc and unfortunatly there is no way to recover it.
Terribly sorry about the mix up
Reply #1June 20, 2008, 07:23:56 am
« Reply #1 on: June 20, 2008, 07:23:56 am »
Sure, delete the nice long post. :P  Good thing I looked at it already.  The untold price of spam...
Reply #2June 20, 2008, 07:59:18 am
« Reply #2 on: June 20, 2008, 07:59:18 am »
Oops, I was thinking of the Truckdoza thread, the long one. Would have sucked to have to repost that.
Reply #3June 20, 2008, 11:21:27 am
gigaz2
  • 626
« Reply #3 on: June 20, 2008, 11:21:27 am »
I remember all my replys, not much lost ;)
Reply #4June 20, 2008, 12:44:59 pm
blkboostedtruck
  • 1535
« Reply #4 on: June 20, 2008, 12:44:59 pm »
yea that was Jims, truckdoza thread i was reading it this morning!
darth gary i think is his username?
Tyler you better run for the hills i seen a grey caddy headed up to canada!
he's prolly going to right to where you work! :shock:
he he just kidding!
Duane
never mind i see his thread is there!
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #5June 20, 2008, 01:46:21 pm
« Reply #5 on: June 20, 2008, 01:46:21 pm »
Quote from: "blkboostedtruck"
he he just kidding!
Duane
its not called the truck DOZA for nothin  :twisted:
Reply #6June 20, 2008, 04:28:07 pm
« Reply #6 on: June 20, 2008, 04:28:07 pm »
yikes!
Reply #7June 21, 2008, 04:20:53 am
« Reply #7 on: June 21, 2008, 04:20:53 am »
Good old google
VW Golf 91
Hello, i'm new around here, I have a VW Golf MK3 from 1991 with AAZ motor and i'm from Portugal.
I have some mods on my AAZ like a Garrett T2 original from 1.9l Golf Mk3 with 1bar pression, Intercooler from Audi A4 TDI AFN 110hp, increase of fuel, no catalisator, pin of LDA 1.6 TD.
I like the power of him right now but I guess maybe he can produce more. One thing that is bothering me is that in 5gear when achieves 3600rpm the car begin to maintain the power and don't have enough power to pass the 4000rpm on straigh line  It seems it misses something and the car begin to smoke black and not to increase the speed.
What could be working wrong on the pomp of my AAZ?
Thank you and hope to learn a lot with you guys!
carrizog60
not enough boost to clear diesel soot
welcome
VW Golf 91
ah..so what you suggest? more pressure on turbo?
Thanks for the welcome CGP mate
VW Golf 91
no more opinions??
thats a pretty dinky turbo. i'd say garrett T3 for your application, although the T2 does spool nice down low, it lacks up top. you could try increasing the boost pressure as stated above. for a quick test you can bock the wastegate line and use your foot the manage the boost and keep an eye on the smoke. keep boost below 18 psi if you can as a T2 isn't as robust as the T3 (some guys running 30+ psi on them)
VW Golf 91
T2 is nice on low but when my AAZ achieved 3000rpm the turbo give another kick..like my old K24 did but with no low power! This kick is better feeled on 3 and 4 gear passing the 3000rpm. But that second kick is not to hard like the K24 but is a pretty good kick help
VW Golf 91
What do you say about pump issue? 1.6GTD pump on a AAZ or only the head of the 1.6 on a 1.9 pump?
gigaz2
9mm plunger on 1.9 camplate, governor mod done to the pump.
K24 with welded wastegate.
pressure and EGT gauge are compulsory!
at least pressure, but prepare to melt things
and welcome
VW Golf 91
On what pump is the 9mm plunger? and what is governor mod
gigaz2
on the RA/SB versions of 1.6td, the 80hp versions.
the governor mod is on the diy section, not advisable for first mods.
check "banza"'s project on CGP
VW Golf 91
How many mm have the plunger original from the 1.9 pump? I have a original 1.9 pump on my AAZ but some pieces on the head of the pump are not good as they should be, interior, and maybe i will buy a 1.6 pump and I was woundering to put the head of the 1.6 on the 1.9, is that possible plug&play? And it will give any advantages?
gigaz2
8mm on the JR
9mm on RA/SB
8mm on AAZ (cam disk has more lift)
but you can't know for sure, I just took my JR apart, its a mechanical lifter block and the plunger is 9mm
