Author Topic: cluster questions  (Read 3924 times)
June 18, 2008, 06:49:09 pm
smoken u
  • 231
cluster questions
« on: June 18, 2008, 06:49:09 pm »
got a cluster with a tach in ti from a 90 diesel jetta, instaled it in the car, everyting else works but the tach. have the w terminal connected
, but have not been able to trace it to the 7 pin connecter in the cluster, doese any one know if the w terminal wire changes from the colour of black/red before it comes to the connector in the cluster.
also my oil light works fine, but myu battery light comes on until I blip the "loud pedal" then it turns off.
If anyone can help it would be greatly appreciated.
1990 VW jetta 1.6 td, 2.5" exhaust, no muffler, governor mod 2010 edition, K&N filter. and now 66 hp and 136 ftlbs.
project 1.6 liter in the works  :)
You don't rev a VW diesel, you increase the clatter.
Reply #1June 18, 2008, 07:13:46 pm
Possum79
  • 276
    • http://www.poscarclub.com
cluster questions
« Reply #1 on: June 18, 2008, 07:13:46 pm »
The battery light is common. Goes off once you rev it up a little bit right after a start. If it goes back on then you have issues.
1979 VW Rabbit Diesel L
Reply #2June 18, 2008, 08:20:50 pm
cluster questions
« Reply #2 on: June 18, 2008, 08:20:50 pm »
i remember one year going out to warm up the car in the winter...  come back about 8 mins later to find it dead.  (gasser with weak battery, cold cold night)...  boy did i feel dum  :oops:  :lol:
Reply #3June 19, 2008, 04:54:31 pm
smoken u
  • 231
cluster questions
« Reply #3 on: June 19, 2008, 04:54:31 pm »
ok. I have 12 volts off the w terminal wire, and when I connect the jumper, I went and bought another cluster, just in case it was the cluster that was bad, reconnected still dosen't work even with a jumper to the pin that the tach is connected to.
 My car never came with a tach from factory, is there any wiring or parts that are left out that must be installed for the tach to work.
thewhole cluster is from a 90 jetta td that had a tach in it.
