Removing AAZ Head
Topic: Removing AAZ Head (Read 3345 times)
June 12, 2008, 04:38:59 pm
homerj1
Removing AAZ Head
June 12, 2008, 04:38:59 pm »
I'm removing a AAZ cyl. head from my 95 Golf next week.
Can anyone clarify the type of socket required to move the head bolts?
It was suggested that a "special socket" is required - and since I don't have close access to the car, I can't check.
Thanks
Aivars
June 12, 2008, 04:48:24 pm
Removing AAZ Head
June 12, 2008, 04:48:24 pm »
Triple square, like
these
. Get good quality ones!!
June 13, 2008, 02:10:01 am
homerj1
Removing AAZ Head
June 13, 2008, 02:10:01 am »
Thanks! Do you know what size I would need?
Aivars
June 13, 2008, 06:29:07 am
Removing AAZ Head
June 13, 2008, 06:29:07 am »
Not off the top of my head. 10 mm maybe?
June 13, 2008, 06:29:22 am
Removing AAZ Head
June 13, 2008, 06:29:22 am »
oops, double post
June 13, 2008, 06:59:09 am
Removing AAZ Head
June 13, 2008, 06:59:09 am »
12mm i believe
June 13, 2008, 09:57:34 am
Removing AAZ Head
June 13, 2008, 09:57:34 am »
Quote from: "jtanguay"
12mm i believe
Yep
June 13, 2008, 10:18:54 am
Removing AAZ Head
June 13, 2008, 10:18:54 am »
IMPORTANT SAFETY TIP (which you probably already know):
Loosen them slowly, incrementally, and in the diagonal sequence listed in the service manual:
else warping may result... the factory spec for straightness is very very tight (2 thou).
June 14, 2008, 03:33:37 am
homerj1
Removing AAZ Head
June 14, 2008, 03:33:37 am »
Thanks!
Final question:
On the official VW tool, I found on the Internet, the trip square
12pt part is about 4 inches in length.
http://www.toolsource.com/head-bolt-socket-3452-audi-p-92548.html
Is the shank length show on this tool necessary to clear something on the head?
Or can I have a short shank and just use an extension?
I can get the 12m 12pt with a short shank locally.
thanks
Aivars
June 14, 2008, 06:53:01 am
Removing AAZ Head
June 14, 2008, 06:53:01 am »
Should be no problem with a shorter one and an extension.
June 14, 2008, 07:39:45 am
homerj1
Removing AAZ Head
June 14, 2008, 07:39:45 am »
Thanks!
Removing AAZ Head
