Author Topic: 84 quantum TD project  (Read 5201 times)
June 09, 2008, 06:20:02 pm
jackbombay
  • 599
« on: June 09, 2008, 06:20:02 pm »
I'll post progress here as it happens.
  Details, I got the car for free as it has a bad hole.
  It was kind of a hassle to get the compression tested, one of the fuel lines was stuck on the pump (the 14mm fitting was unscrewing from the pump instead of the 17mm fuel line nut unscrewing from the 14mm fitting) so I had to pull the pump to remove the fuel line and reinstall the pump.
  Also the #3 injector is a bit of a hassle to get out as the LDA is in the way so I made a special tool to remove it,
The square is welded on from the back through a hole,
In use
I'll pull the head tomorrow and see whats up with hole number 4.
Comp test numbers, COLD engine, about 60*F out today
#4 ~10 PSI
#3 320 PSI
#2 340 PSI
#1 345 PSI
  What is normal for a cold engine? I always see hot engine numbers.
  I did run the car for a bit, it was shaking quite a bit :lol:  but there was no exhaust or pressure in the coolant reservoir so I'm thinking its a burnt valve, but maybe a holed piston. The car broke down while running WOT up 3 miles of %10 grade, the PO did that 2 times a day 5 days a week for 2 years till the car broke, stock fueling so it seems like it shouldn't have been able to "kill itself" but ~4 minutes of WOT is quite a bit of heat as well, he did say when it happened there was coolant all over under the hood but he couldn't tell where it came from, but the temp gauge on the dash never climber at all. I have yet to see any coolant leaking, but that does really point to bad head gasket.
  Pics of the car and more details here.
Reply #1June 09, 2008, 07:36:46 pm
jackbombay
  • 599
« Reply #1 on: June 09, 2008, 07:36:46 pm »
Did the 84 TDs come with solid lifter heads or hydraulic?
Reply #2June 09, 2008, 08:10:24 pm
« Reply #2 on: June 09, 2008, 08:10:24 pm »
more than likely solid.
look for 2 humps in the front of the cylinder head if only one big one in the center you should have a solid lifter head. If you have 2 a smaller one to the left of the bigger one then should be a hydro.
Reply #3June 10, 2008, 09:55:02 am
shegel
  • 312
« Reply #3 on: June 10, 2008, 09:55:02 am »
i thought the limit for hyd and mech heads was 86 his 84 should be mech
1986 Golf 1.6l non turbo (R.I.P.)
1999.5 jetta (bought with 122145)
1969 karmann ghia(diesel swap dream)(most likely going to be subaru powered)
1998 jetta tdi (parents car)
Reply #4June 10, 2008, 10:35:05 am
MJF
  • 581
« Reply #4 on: June 10, 2008, 10:35:05 am »
If itīs original engine, itīll be mech. Check the humps from block, some aftermarket mech heads have both humps.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #5June 10, 2008, 04:27:31 pm
jackbombay
  • 599
« Reply #5 on: June 10, 2008, 04:27:31 pm »
Quote from: "MJF"
  The humps are on the side of the block facing the injector pump, right?
  Assuming it is a mech head (I'm pretty sure it is all original) can I still use a 1.9 TD metal head hasket? On mikew's website he lists the 1.9 HG as though it only fits the hydraulic heads, can it be modified to fit a 1.6 mech head?
Reply #6June 10, 2008, 08:29:48 pm
jackbombay
  • 599
« Reply #6 on: June 10, 2008, 08:29:48 pm »
   This is the hump, right? So it is a solid lifter head.
Reply #7June 10, 2008, 08:30:34 pm
jackbombay
  • 599
« Reply #7 on: June 10, 2008, 08:30:34 pm »
Can I run a 1.9 metal HG with this head?
Reply #8June 10, 2008, 10:22:06 pm
jackbombay
  • 599
« Reply #8 on: June 10, 2008, 10:22:06 pm »
Ahhh, thanks for the pic, mine is a solid lifter head.
  So can I use a metal 1.9 HG with the solid lifter head? Are they available in different thicknesses like the normal HGs? Can the metal HG be modified to work on a solid lifter head?
  On myke_w's website it lists the metal HG as,
1.6/1.9 Metal Headgasket – Reinz/Elring - (hyd) -(specify # of notches) = $ 50
Reply #9June 13, 2008, 09:09:20 pm
jackbombay
  • 599
« Reply #9 on: June 13, 2008, 09:09:20 pm »
I got the head off, the down pipe nuts were a PITA, I had to use almost 2 beers to get them off :evil:
 The good news, none.
  The bad news, the pre-cup fell out of the head and had been wallowing out the hole in the head for who knows how long, it wore a decent bit of piston off, and it crumbled away a bit of the top edge of the cylinder and those specs of cast iron lodged in the rings and the cylinder wall is decently scored so it'll need at least 1st oversized pistons and a new head, this one is certainly not rebuildable.
  Pics,
Check out how the precup wore through the HG all the way to the deck,
And here are the scuffs on the cylinder wall,
  The turbo has an odd extra line from the waste gate actuator to the non pressure side of the comp housing, I'm not sure what thats for,
  Its a garret, I think a T3, no garret part number, just this plate
  The turbo is in very good shape, spins freely and hardly ant play at all.
  I'll get the block out soon, I need to call some machine shops.
  A new head will run about $575...
  2 of the other precups were slightly loose, but hadn't caused any damage.
  How often do the precups come loose and wreck stuff?
Reply #10June 14, 2008, 03:27:58 pm
myke_w
  • 1099
« Reply #10 on: June 14, 2008, 03:27:58 pm »
def a T3
Also, a nice rebuilt head shouldn't be terribly expensive..
Someone here can definitely help you.
Looks like you'll need pretty much a complete rebuild of course, but it's worth it if you like the car enough :)
Reply #11June 14, 2008, 04:00:17 pm
jackbombay
  • 599
« Reply #11 on: June 14, 2008, 04:00:17 pm »
Quote from: "myke_w"
def a T3
  Aluminum head rebuilders in Portland Oregon quoted me $575 for a new head, but if someone here sells them I'd rather spend my money here.
  The car is in such good shape that it would be a real shame to not rebuild the engine, so, the money will be spent 8)
Reply #12June 14, 2008, 04:07:37 pm
myke_w
  • 1099
« Reply #12 on: June 14, 2008, 04:07:37 pm »
I might be able to help you out.
let me see what I can find in the garage, I can possibly have my machine shop work one over for me in a hurry.
Myke
Reply #13June 14, 2008, 04:21:08 pm
jackbombay
  • 599
« Reply #13 on: June 14, 2008, 04:21:08 pm »
Myke
  Cool, it wouldn't have to be too fast as I still need to find a machine shop around here for the bottom end.
Reply #14June 14, 2008, 04:21:29 pm
Mark(The Miser)UK
  • 1557
« Reply #14 on: June 14, 2008, 04:21:29 pm »
Welcome back to Quantum land Jack.... I thought you'd died on your sword after that QTDAWD experience :shock:
Mark-The-Miser-UK
