throttle cable..
Pages:
Topic: throttle cable.. (Read 5461 times)
Reply #15
June 13, 2008, 10:57:39 am
Sc0rian
User+
throttle cable..
Reply #15 on:
June 13, 2008, 10:57:39 am »
i really dunno whats up..
ive sure the throttle is fitted ok, it feels fine, it goes right to the max, and revs right to the limit..
but its ULTRRRRRRRA slow on the road, turbo aint spalling up properly, but if i really rag the tits of it, it does get up to 5psi... i guess it aint got enough exhaust gases???
i dunno whats up with it.. and no garage around my area has a clue
Reply #16
June 13, 2008, 11:08:15 am
throttle cable..
Reply #16 on:
June 13, 2008, 11:08:15 am »
when you're right on the pedal do you get any black smoke out the exhaust???
Reply #17
June 14, 2008, 03:13:45 am
Sc0rian
User+
throttle cable..
Reply #17 on:
June 14, 2008, 03:13:45 am »
Quote from: "jtanguay"
no... i don't..
i have to admit, it does seem to be runnin very slightly different..
Reply #18
June 15, 2008, 06:57:50 am
Sc0rian
User+
throttle cable..
Reply #18 on:
June 15, 2008, 06:57:50 am »
gears seem to be longer??
when ragging it, i can go to bout 30+mph in 1st with the engine screaming, it never used to do that... i used to run out of puff easily by 20mph..?
Reply #19
June 15, 2008, 02:58:03 pm
Sc0rian
User+
throttle cable..
Reply #19 on:
June 15, 2008, 02:58:03 pm »
anyone
Reply #20
June 15, 2008, 03:09:20 pm
throttle cable..
Reply #20 on:
June 15, 2008, 03:09:20 pm »
If you pulled the throttle plate off without marking where it indexed to the throttle shaft then that's what's wrong.... as far as I know trial and error is the only way to rediscover where it works correctly.
Reply #21
June 17, 2008, 10:30:09 am
Sc0rian
User+
throttle cable..
Reply #21 on:
June 17, 2008, 10:30:09 am »
i spent all day playin with it today, ended up messing around with the max fuel screw, and after loads of playin bout its all fast again
Pages:
throttle cable..
