Author Topic: throttle cable..  (Read 5451 times)
June 09, 2008, 10:22:32 am
Sc0rian
  • 25
throttle cable..
« on: June 09, 2008, 10:22:32 am »
ok.. i went to change the pin in my car, and my mate thought you had to undo the throttle cable, anyways, by the time i got back from having a piss, he'd pulled it off. Now we/he can't get it back together properly.
We got it back together finally, took it for a blast, and i'm not getting full throttle, looking into it I believe its because there isn't enough tension on the spring, how ever im really not sure.
I cant find any tech diagrams or anything, could someone post some pictures of theres up, or how its meant to go back together..
asap would be great, as my car aint working now :(
Reply #1June 09, 2008, 11:01:46 am
Possum79
  • 276
    • http://www.poscarclub.com
throttle cable..
« Reply #1 on: June 09, 2008, 11:01:46 am »
Are you talking about the spring setup or the cable itself?
1979 VW Rabbit Diesel L
Reply #2June 09, 2008, 11:59:55 am
Sc0rian
  • 25
throttle cable..
« Reply #2 on: June 09, 2008, 11:59:55 am »
spring setup
Reply #3June 09, 2008, 12:44:09 pm
Sc0rian
  • 25
throttle cable..
« Reply #3 on: June 09, 2008, 12:44:09 pm »
1.6td mk2 :)
sorry should of said
Reply #4June 09, 2008, 03:16:56 pm
Possum79
  • 276
throttle cable..
« Reply #4 on: June 09, 2008, 03:16:56 pm »
http://www.vwdieselparts.com/forum/viewtopic.php?t=6694
theres some pics way down the page and someone posted one all the way at the bottom. Also someone posted not to long ago and good pic on this forum but I didnt save a link and youd really have to search for it.
Reply #5June 10, 2008, 04:20:25 am
Sc0rian
  • 25
throttle cable..
« Reply #5 on: June 10, 2008, 04:20:25 am »
cheers mate
pics dont really show what i need, also looks different
where does the black lip and the bottom spring go?
Reply #6June 10, 2008, 05:10:42 am
dillenger1
  • 777
throttle cable..
« Reply #6 on: June 10, 2008, 05:10:42 am »
Is the "black lip"  concave shaped?do you have two springs or just one?
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #7June 10, 2008, 05:12:47 am
Sc0rian
  • 25
throttle cable..
« Reply #7 on: June 10, 2008, 05:12:47 am »
yeah its concave shaped, and just 1 spring.
other bits:
Reply #8June 10, 2008, 01:35:40 pm
dillenger1
  • 777
throttle cable..
« Reply #8 on: June 10, 2008, 01:35:40 pm »
the small cup preloads the bottom end of the spring,allowing you to twist to match up the idle hash mark on the throttle lever w/the one on the shaft itself.hope this helps a little. i know i had trouble when i attempted this.
Reply #9June 10, 2008, 04:32:47 pm
Sc0rian
  • 25
throttle cable..
« Reply #9 on: June 10, 2008, 04:32:47 pm »
Quote from: "dillenger1"
i understand but.. how does it preload the spring, can you explain how do i do it? sorry...  :oops:  :oops:
Reply #10June 10, 2008, 07:59:49 pm
vanagonturbo
  • 639
    • Fine Tuning
throttle cable..
« Reply #10 on: June 10, 2008, 07:59:49 pm »
punch your friend.
Sorry I couldnt help more...
Reply #11June 10, 2008, 08:03:29 pm
throttle cable..
« Reply #11 on: June 10, 2008, 08:03:29 pm »
I did the governor mod on my 84 rabbit and ran into this. It was an NA but same deal in the pictures here. I don't know if I did it correctly but I had the benefit of knowing where it was (pictures) when I took it off. I put the line on the shaft about exactly in the middle of all the lines on the lever... if it were a clock 12 and 6, mine was just slightly to the right of 12 but pretty dead nuts on 6.
I put it on, barely tightened the nut enough so it wouldn't move, pushed the lip of the spring with a screw driver until I could grab it with needle nose pliers and pulled some more. My black piece didn't have a lip on it...might have broken? It is on there now hope it helps for your project.
Reply #12June 11, 2008, 02:28:59 am
Sc0rian
  • 25
throttle cable..
« Reply #12 on: June 11, 2008, 02:28:59 am »
cheers mate.. can you share some pics???  :D
Reply #13June 11, 2008, 03:08:19 am
dillenger1
  • 777
throttle cable..
« Reply #13 on: June 11, 2008, 03:08:19 am »
theres a stop in the body of the pump,thats where the bottom end of the spring tensions.the concave cup takes the top end of the spring.while rotating you should be able to preload the spring.You have to preload untill you come around and line up the hash marks  on the throttle shaft and lever.It takes a little patience and muscle.when theyre lined up then start your nut and washer on the shaft.
Reply #14June 11, 2008, 05:37:09 am
Sc0rian
  • 25
throttle cable..
« Reply #14 on: June 11, 2008, 05:37:09 am »
i dunno if ive fitted it right, but its on.. but i seem to be only getting 1/4" throttle?? its really slow, turbo dont spall up.. maybe there isnt enough tension in the spring??
