Author Topic: IP outlines - check valves?  (Read 2148 times)
June 07, 2008, 11:32:44 am
Gutta Perka
  • 6
« on: June 07, 2008, 11:32:44 am »
On the back of the IP there are four check valves starting the the injectionlines to the motor.
I have some Boschpumps with different check valves.
Are they fitted to the sprayers?
Can I take a set of these checkvalves and interchange with any other Bosch-IP-pumps checkvalves?
They have no number printed on them so they doesen't seem to be correlated to the sprayers.
/Gutta
Reply #1June 07, 2008, 02:33:17 pm
« Reply #1 on: June 07, 2008, 02:33:17 pm »
If you are talking about the delivery valves on the head you shouldn't really mix and match them
Reply #2June 07, 2008, 02:55:24 pm
gigaz2
  • 626
« Reply #2 on: June 07, 2008, 02:55:24 pm »
two types: return flow restriction and constant pressure
the first are used on IDIs and the latest on TDIs.
they have springs and shims to allow them to be tailored to a specific engine.
so... as burn_your_money said ;)
