Author Topic: 1.6 TD COMPRESSION RESULTS  (Read 5369 times)
June 07, 2008, 04:12:11 am
rabbitpower
  • 45
« on: June 07, 2008, 04:12:11 am »
I popped the injectors out and did a compression test last night before I pull the engine. It is a stock 86 TD engine w 170k. I was a little surprised. The results are
1-----490psi
2-----440psi
3-----420psi
4-----490psi
The engine was bone cold. I did not that it took a few cranks to get to max pressure. I am not sure how long it should take or how much the pressure should jump. I did notice that the pressure bled down to 300 psi rather quickly. Could be the gauge, or my rings and pistons I guess.
Any thoughts from anyone on these results?
Reply #1June 07, 2008, 11:16:34 am
« Reply #1 on: June 07, 2008, 11:16:34 am »
Every compression tester I've seen is supposed to hold the max pressure untill you push a little button.
If I had that high of numbers I would be so happy.....I think 498 was new spec. 71psi is the max difference between cylinders so your barely good. Mine averaged 370psi a year ago when I checked. :(
Reply #2June 07, 2008, 11:51:45 am
smutts
  • 720
    ClackClackClackClackClack
« Reply #2 on: June 07, 2008, 11:51:45 am »
I wish those were for my old GTD.
Being a bit of a bodger, I use this method. Find very steep and quiet hill, stop, turn off ignition, engage a suitable gear, and let off the hand brake. If you have the right gear, the car will stop on each cylinder compression, how long depends on how fast that air leaks through rings, valves, and assorted holes. Seven, one, three and five seconds suggests that a proper compression test would only say bad news.
While road testing the "new" GTD I got eight, eight, six & seven seconds. So I bought it. Best £500 i've spent in a while.   :wink:
Reply #3June 08, 2008, 04:09:19 am
rabbitpower
  • 45
« Reply #3 on: June 08, 2008, 04:09:19 am »
Quote from: "smutts"
Just for giggles I put a cap full of oil in one of the low cyl and it went from 420 to 540psi. I have a spare set of Turbo rings so I may just toss them in and see what happens. That road test is interesting, I can't wait to try it. Thanks for the info!
Reply #4June 28, 2008, 05:16:15 am
smutts
  • 720
« Reply #4 on: June 28, 2008, 05:16:15 am »
Oil? Probably treacle for mine. :D
