Author Topic: Fuel pump scew  (Read 2751 times)
June 05, 2008, 08:35:30 pm
VWralley
  • 50
Fuel pump scew
« on: June 05, 2008, 08:35:30 pm »
anybody got some pics or description to help a newbie adjust the fuel screw? put a new pump on an its running insanely rich, any help would be appreciated
77 rabbit 16v MSnS
85 Audi 4KQ
81 Rabbit 4dr diesel
Traksclothing.com Demonrally.com
Reply #1June 05, 2008, 08:38:31 pm
vanagonturbo
  • 639
    • Fine Tuning
Fuel pump scew
« Reply #1 on: June 05, 2008, 08:38:31 pm »
did you set the pump timing? Did you set the pump timing with the advance knob pushed in?
n00b!!
Reply #2June 05, 2008, 09:00:12 pm
VWralley
  • 50
Fuel pump scew
« Reply #2 on: June 05, 2008, 09:00:12 pm »
nope, put it on at about the same spot as the previous pump and its been running pretty well its just super rich
i got a good friend with all the tools to set the timing, should i just go up an have him set it all for me?
77 rabbit 16v MSnS
85 Audi 4KQ
Reply #3June 06, 2008, 11:34:06 am
rabbitman
  • 2788
Fuel pump scew
« Reply #3 on: June 06, 2008, 11:34:06 am »
A rich diesel just revs up. I'd say timing is off, probably retarded.
Reply #4June 06, 2008, 01:57:28 pm
gigaz2
  • 626
Fuel pump scew
« Reply #4 on: June 06, 2008, 01:57:28 pm »
yup, same case as I.
you get unburnt fuel from the exhaust no matter how low the rpm right?
you can have air in the IP, a leak somewhere or timing issues.
or all of the above
Reply #5June 06, 2008, 03:06:25 pm
Fuel pump scew
« Reply #5 on: June 06, 2008, 03:06:25 pm »
I'll place a vote for retarted timing as well.
Reply #6June 06, 2008, 03:06:48 pm
VWralley
  • 50
Fuel pump scew
« Reply #6 on: June 06, 2008, 03:06:48 pm »
no just on hard accel, an if i open er up all the way it just pours black smoke out, it def makes cars dissapear! haha
it runs great, starts up perfect, but i only need to pull the lever out about half way for just a few min in the morning. it smoke a little bit right off idle an then if i stay in it, it starts pouring black smoke, i cant hit full throttle cause its black way before that haha
77 rabbit 16v MSnS
85 Audi 4KQ
Reply #7June 06, 2008, 03:09:37 pm
VWralley
  • 50
Fuel pump scew
« Reply #7 on: June 06, 2008, 03:09:37 pm »
ok, i wont touch the fuel screw till i get my timing dialed in...thanks fellas! 8)
77 rabbit 16v MSnS
85 Audi 4KQ
Reply #8June 07, 2008, 10:26:04 am
vanagonturbo
  • 639
    • Fine Tuning
Fuel pump scew
« Reply #8 on: June 07, 2008, 10:26:04 am »
Just come up to the shop today and I will help you set the timing
