Author Topic: Glow Plug Relay Update????  (Read 6945 times)
May 30, 2008, 05:41:44 am
Kneale Brownson
  • 120
« on: May 30, 2008, 05:41:44 am »
My ETKA says the glow plug for my 1994 Jetta TD is part # N 102 130 02.   A parts source I use regularly says that part number item is no longer available and has been replaced by a fast (seven seconds) glow plug that requires an updated relay.  (See  http://www.autohausaz.com/search/product.aspx?sid=orblpn45pebzgd45pwpbhq45&partnumber=n10213002)
How do I know whether I have the updated relay?
Reply #1May 30, 2008, 02:04:47 pm
Possum79
  • 276
    • http://www.poscarclub.com
« Reply #1 on: May 30, 2008, 02:04:47 pm »
I read somewhere that usually you can tell by the color of the text on the relay. I think they said white text was fast. Slow is some other color. Also by the nuts on the glowplugs themselves. Something about aluminum or brass nuts. I'm trying to figure out where I read that at.
Don't quote me on any of that untill I find where I saw it.
1979 VW Rabbit Diesel L
Reply #2May 30, 2008, 02:23:00 pm
Possum79
  • 276
« Reply #2 on: May 30, 2008, 02:23:00 pm »
Red letters is fast system and plugs will have a brass nut. White lettering is slow system with aluminum nut on the plugs
http://vincewaldon.com/images/documents/protraining_diesel_77-83.pdf
Page 37 of the pdf file.
Courtesy of vincewaldon.com
Check out other stuff on that site for excellent vw how-to.
Of course I would recommend getting the part number from your relay and cross referencing it to fast systems.
Reply #3June 01, 2008, 03:47:52 am
Kneale Brownson
  • 120
« Reply #3 on: June 01, 2008, 03:47:52 am »
Vince's book says the slow system powers the glow plugs for 90 seconds, while the fast system lasts just 15.
My car's glow plugs do not have brass nuts, but the power to the plugs goes off within 15 seconds after turning on the key.
Mine also fail to light up a test light if I disconnect the wiring to the plugs and put the light between the battery positive terminal and the plugs.
So maybe I have slow plugs on a fast relay???  And they've died???
Sure is a PITA to get to the plugs.  Do you ordinarily have to pull all the plumbing to the injectors in order to change the glow plugs?
Reply #4June 01, 2008, 04:28:33 pm
Possum79
  • 276
« Reply #4 on: June 01, 2008, 04:28:33 pm »
Ive yet to change mine so i do not know how difficult it is. Supposedly you can do them with out removing stuff but its tuff. The hard part is the two behind the injection pump. I would take you relay out and get the number from it. Someone can probably look it up to see if its fast or slow. I would assume if there was a cross problem in the fast to slow it would be a fast plug with slow relay. cheaper to change.
I plan on buying the Bosch kit from autohaus to do mine. 80 bucks for relay and plugs if its not on backorder.
are all the plugs not lighting the test light? you have to completely disconnect the bus bar and wires to it in order to test. Also make sure your light actually works.  :wink:
edit: I can also say i know my system is on a slow relay but my light only stays on for 15-20 seconds. I read that the fast is 7 seconds while the slow is up to 60 seconds. It all depends on the temp sensor and things. It is wired to the relay to prove if it needs the plugs or not.
Reply #5June 02, 2008, 06:01:08 pm
Kneale Brownson
  • 120
« Reply #5 on: June 02, 2008, 06:01:08 pm »
Well, I pulled the relay (PITA) to find it has the white lettering, which Vince's booklet says means it's the "normal" slower relay system.
Where can I get the slower glow plugs?
Reply #6June 02, 2008, 06:52:02 pm
« Reply #6 on: June 02, 2008, 06:52:02 pm »
Bosch Duraterms are compatible with both systems.
Actually, the "fast" system is so named because you can start "faster", but the plugs stay on for quite a bit longer (3 minutes or more) to improve driveability with a cold engine.
Pretty sure the entire "slow" system is NLA from VW anyways... get the Duraterms and away you go.
Reply #7June 02, 2008, 06:53:54 pm
« Reply #7 on: June 02, 2008, 06:53:54 pm »
Duraterms are the way to go. They are self monitoring so you can't burn them out from them being on too long.
Reply #8June 02, 2008, 07:13:36 pm
Possum79
  • 276
« Reply #8 on: June 02, 2008, 07:13:36 pm »
Quote from: "Vincent Waldon"
Actually the slow relay is avaliable which is stupid to me, just the plugs are not avaliable.
Reply #9June 03, 2008, 05:47:56 am
Kneale Brownson
  • 120
« Reply #9 on: June 03, 2008, 05:47:56 am »
Sources for the Duraterms?
Reply #10June 03, 2008, 10:02:42 am
« Reply #10 on: June 03, 2008, 10:02:42 am »
for canadians www.autopartsonlinecanada.com
Not sure for you
Reply #11June 03, 2008, 11:32:38 am
Kneale Brownson
  • 120
« Reply #11 on: June 03, 2008, 11:32:38 am »
Got 'em on order from these guys:
http://www.autopartswarehouse.com/
Had to make direct contact because their website catalog is less than complete.  US price a buck higher or so than the Canadian website.
Reply #12June 03, 2008, 12:46:17 pm
burnt_servo
  • 278
« Reply #12 on: June 03, 2008, 12:46:17 pm »
Quote from: "burn_your_money"
so a person could make a manual push button type system to power the glow plugs and not worry about  them being on too long and burning out  ? ... aka suzuki diesel conversion ......
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #13July 09, 2008, 04:39:32 pm
Possum79
  • 276
« Reply #13 on: July 09, 2008, 04:39:32 pm »
just thought I'd chime in late to say the autohausaz.com part 80010 is a duraterm plug. I emailed autohaus about it because I just was thinking i need some.
Reply #14July 09, 2008, 05:47:29 pm
gigaz2
  • 626
« Reply #14 on: July 09, 2008, 05:47:29 pm »
Quote from: "burnt_servo"
well yes, that would work.
the timer system is only there for convenience, who would want to follow a complicated starting procedure when you can just wait for the light to go off to turn the key?
well, Im thinking about putting a similar switch on the engine compartment, together with a start button, because I spend more time in the engine bay than behind the wheel anyway :D
