Author Topic: quick timing question, at my witts end...  (Read 2622 times)
May 27, 2008, 06:43:10 pm
mufflerbearing
  • 61
« on: May 27, 2008, 06:43:10 pm »
when timing the pump. the bentley instructs to set a 1mm preload after turning the crank ccw til the gauge stops moving. then turning it back to tdc and turning the pump body to set the pump to the proper lift.
if i were aiming for .93mm would i set the lift to .93mm or 1.93mm?
also, if anyone has any alternative methods for setting pump lift timing, please share them with me. i can not, for the lift of me, get this thing to run right...
-j
Reply #1May 27, 2008, 07:03:17 pm
« Reply #1 on: May 27, 2008, 07:03:17 pm »
If you have 1.00mm preload you are setting it to 1.93 +/- 0.05ish.
If you can't get it to 1.93mm then you are off a tooth. Make sure the stupid cold start is pushed in :oops:
Reply #2May 28, 2008, 12:42:29 am
mufflerbearing
  • 61
« Reply #2 on: May 28, 2008, 12:42:29 am »
oh... that changes things a little...  :roll:
-j
Reply #3May 28, 2008, 12:58:34 am
mufflerbearing
  • 61
« Reply #3 on: May 28, 2008, 12:58:34 am »
i feel like an idiot...
its a little too late to fire it up, but ill try it in the morning. im pretty sure thats all i needed to do.
i was over here trying to figure out how to get the timing to drop down to .93mm... i had retarded the pump 2 teeth trying to do this and now i feel like an idiot.
1.93mm, here i come.
-j
Reply #4May 28, 2008, 09:07:13 am
saurkraut
  • 904
« Reply #4 on: May 28, 2008, 09:07:13 am »
I think my Bentley says the preload should be 2.5 or greater.  Double check yours.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #5May 28, 2008, 10:04:47 am
mufflerbearing
  • 61
« Reply #5 on: May 28, 2008, 10:04:47 am »
thanks...
now i feel
-j
Reply #6May 28, 2008, 02:12:11 pm
« Reply #6 on: May 28, 2008, 02:12:11 pm »
haha was this the problem when u were posting on vortex?
Reply #7June 07, 2008, 01:09:38 am
mufflerbearing
  • 61
« Reply #7 on: June 07, 2008, 01:09:38 am »
yep, everything is great now and ive been driving the piss out of it.
-j
Reply #8June 07, 2008, 04:20:06 am
« Reply #8 on: June 07, 2008, 04:20:06 am »
excellent :D
Pictures or it didn't happen though
Reply #9June 08, 2008, 10:15:58 pm
mufflerbearing
  • 61
« Reply #9 on: June 08, 2008, 10:15:58 pm »
